6 hours ago, tylink720 said:
Any current recs for a good budget reg? I don’t want to buy some cheap eBay stuff, but also don’t want to drop $500 on just a regulator. I’ve seen some for about $140-$170 like Tomei, P2M, NRG, AEM, ect
I vote Radium direct mount regulator. It's super nice mounting the reg directly on the rail. Keeps everything neat and tidy, saves space and saves on fittings/hoses/etc
  • Like 1
Direct mount to stock rail though? I'd think not so much with that one.
My crystal ball says if he is buying upgraded fuel pumps, drilling out a venturi, buying an upgraded fuel pressure regulator, if he doesn't already have an upgraded rail/injectors, it's only a matter of time now lol.
Stock rail but 1000cc Bosch injectors. Is there a reason for Tomei being junk? Seems like the easiest option since it has fittings and a mount already included
Edited by tylink720
1 minute ago, tylink720 said:
FIXED
I installed the new fpr and turned it down to 43 psi. Idles nicely at 38ish psi now with the vacuum line attached.
thanks for the help!
please post up skids :P
  • Like 1
Lol I hope to take it out this weekend and rip it around. I’m curious to see how far off my fuel map is now that I’m running 10psi less base pressure. I do need to get a pressure sensor next season to keep an eye on it.
  • Like 1
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
