I've been told that CA18DET gearboxes and RB20DET gearboxes are similar and match up with no probs, and apparently SR20DET gearboxes do too with minimal modification.
Which got me curious... can one take a 6 speed gearbox off an S15 Turbo (Type R whatever you wanna call it) and chuck it in an R32?
Also how well does it mate up with an RB25DET (sicne I'm doin an engine swap anyways).
Also how's the reliability of an S15 6 speed gearbox? I've been led to believe that at over 400hp it shits itself... I'm looking at around the 375 to 430hp range once my pet project is done, so this is important.
https://www.sau.com.au/forums/topic/48575-s15-6-speed-gearbox-in-r32/
yeah, the 6 speeds are meant to be dodgier.. Some of the S15 guys actually go for the older s14 5speed boxes when the new ones die.
also: I seem to remember reading that the 6speed wasn't fantastic as the ratios weren't that suited either. Some of the gear changes were especially too short (hmm rex there too..lol)
i think the box is very good, but yes it is weak compare to other nissan gearbox.
ratios is nice, when u drive up the hill it's a lot better than my R33
go for nismo S15 6 speed then
around $5000
not hell lot more than a R34 Gear box but u got 6 speed
If you are planning on fitting a 6 speed from an S15 don't put in a massive twin plate clutch or anything stupid like that. This is the major contributor to failed gearboxes in S15's.
There are many 12 second S15's still running the factory box with no problems and with 250rwkw over at www.nissansilvia.com.
The 3rd gear ratio is fantastic. This is the gear I beat my 2 friends who own R33's. :D
$5000 for a nismo box when a supra 6 speed box made by getrag is around the same price... i'm thinking budget 6 speed here...
also when building up the car I'm aiming for more than 250rwkw. which will be a lot more at the fly and hence the stress on the gearbox as well. So using appropriate clutches etc, what's the max you guys reckon a 6 speed S15 box can handle?
Any other budget alternatives?
i know its not what you are after but i have to correct earlier info that might mislead!!! the pull type r33 gtr boxes are the weakest in the gtr rb series by a long shot as nissan tried to correct problems that where in the r32 boxes but overcompensated and made themselves a whole set of new problems, the series 3 box is better but still no where near as good as the six speeds in japan are holding up to 10 second gtrs and they are getting reliabilty!!!
I recall there was a thread about this a while ago (I was thinking the same thing because I was doing a fair amount of highway driving). The main issue was that the S15 box wouldn't be able to cope with the torque of the RB20...but I've been reading a lot recently that the SR20 makes more torque than the RB20...now I'm confused.
I think it goes like this...
R32 - both GTS and GTR are good strong designs. The RB20 box has a weakness at very high power but you have to get the RB20 to produce 250kW+ first.
R33 - not much problem at all. The RB25 is a just a RB26 box with the front output cut off. "Weaknesses" are that it's a big fat bastard (you'll see if you have a RB25 next to an RB20 box). The Series III R33 GT-R is supposed to have the strongest internals.
R34 - same as the R33 except the Getrag six speed has some problems very well documented on this forum.
S13 - ok box, good design.
S14 - got a bit better, bit stronger.
S15 - six speed is weak compared to the relatively strong Nissan reputation. It's also another big fat bastard.
You must admit that for drivelines strength, Nissan have a good rep. and we've all been lucky. That's why we drive them. Not as a good as Toyota boxes IMO but close enough.
T.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
