I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it
Works are as follows
Head
-Extensive porting
1mm oversized supertech valves
Supertech double springs
Supertech valve guides
Supertech titanium retainers
Tomei solid lifters
Tomei 270 x 10.25 cams
Head drain
Bottom end series 2 rb30 block
Cp ceramic coated pistons
Eagle rods
Romac balancer
Oil restrictions
O ringed blah blah spent a fortune
And will get a girdle because the 30s arent used to handling that much rpm
Nitto billet oil pump
Hypertune plenum
6boost mani
Refurbed astra pump thats the cover for it in the boot
I did have a precision 6262 but sold it because drag car life.
Currently building the ass end full 4 link floater rear end with a 2 speed
But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route.
Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
https://www.sau.com.au/forums/topic/486253-rb2630-build/
2630s work perfectly well.
There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big.
It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
  • Like 1
https://www.sau.com.au/forums/topic/486253-rb2630-build/#findComment-8000397
Posted (edited)
Both heads will be equally reliable or unreliable depending on what you do to them.
Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.
The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.
Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.
RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
Edited by Butters
https://www.sau.com.au/forums/topic/486253-rb2630-build/#findComment-8000398
13 hours ago, MBS206 said:
And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
No doubt barra is a great cheap way to make power but... so many around now I just call them cabs lol. And low revving compared to the rb doesnt sound anywhere near as cool haha. And talk about sacrilege, i love the rbs jist something about them
https://www.sau.com.au/forums/topic/486253-rb2630-build/#findComment-8000416
7 hours ago, r32-25t said:
You’ll want to have the block drilled and tapped to suit 1/2in head studs and the head for the same.
How much power do you intend to make?
Years ago I wanted allllll the power but realistically 700hp would be more than enough for what I want. I started the build with the intention of dragging it. But times change family etc I just want a mad streeter than I can take to powercruise.
https://www.sau.com.au/forums/topic/486253-rb2630-build/#findComment-8000417
Been looking at PRP and how much work and development they've put into making it easier to put the 26 head on. They even make this bracket to tap the idler pulley on, its so awesome how far that stuff has come in the last 10 years.
https://www.sau.com.au/forums/topic/486253-rb2630-build/#findComment-8000418
2 hours ago, lilley's gtr said:
If anyone has done a similar build I'd love to see what they did and why
To help you out... If you head for the "Forced Induction" section of the forum, you'll find these two threads.
RB30 Hybrid Dyno Results.
RB30 Conversion Thread
https://www.sau.com.au/forums/topic/486253-rb2630-build/#findComment-8000429
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
