I'm seeing torque specs all over the place for the OUTER tie rod, but none for the INNER tie rod, where it connects to the steering rack. Even in videos, people are just tightening em up as much as they can with a wrench and that's it.
Anything tightened down without torque makes me nervous. Anyone know what the spec is for it?
https://www.sau.com.au/forums/topic/486282-r-chassis-inner-tie-rod-torque-spec/
13 minutes ago, dyl33 said:
Cant find a torque spec in the R32 gtr manual
But there is one in the silvia manual
Not sure if it's the same
Should be close enough. Noting that 88Nm is equivalent to 2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there.
Let's keep it concise please; the fellow asked for help, not nonsense terms.
R33 steering overhaul torque values are shown here.
  • Thanks 1
6 hours ago, GTSBoy said:
Don't get all high and mighty. Experienced spanner wielders know exactly what effort is required to release an Oof.
Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
  • Like 2
Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque.
How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
Not sure if you're being serious?
I, and all the car people i know, ALWAYS use a torque wrench for wheel nuts. I assumed any car person, apart from tyre centre monkeys with rattle gun in hand, would do it properly.
Anyway, no further reply from me on this unless legit discussion from OP or his query so, over to you, knock yerself out.
  • Nope 1
19 hours ago, hardsteppa said:
Furthermore, to obtain the correct torque value using a torque wrench, use this sort of tool rather than trying to just slip a spanner on there and hoping for the best
sttool2.thumb.jpg.4b1ae7b6dfa53c36467f1b335469e61a.jpgsttool1.thumb.jpg.37d0ba6c933b9d44c13785f36bf0a7fd.jpg
Dang I looked at this for so long until I realised it was for the inner rod. I was so confused. This looks like a great tool. Another injected plastic box for my collection.
I for one am a torquer. I'm far too anxious and neurotic to not use the correct torques whenever I can. I do honestly feel like my wheels will fall off if I dont.
It's a great tool to have, even if you only use it a few times. Cheap and does the job far better than a spanner on there.
I mean, given the number of BMWs you own their tolerance for improper torque is rather low. The number of torque + angle spec bolts and non-reusable bolts in one is nuts.
  • Haha 1
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
