eeek
we use to own a 70's colt as a bush basher, it was RWD just like the lancer of those days. it was quite a good car and very strong.
a mate also has a 83 colt as a second car, efi turbo with about 82kw and stuff all weight. It gives a few people out there a fright when this bunky ass peice of crap blows them away. :)
Shaun
haha.. i passed my driving test in my bf's mums '88 Colt - it was her shitty runabout...probably why she let me drive it...
as for that new one, would be ok if you're after that sort of thing I guess, and "under consideration a high performance turbo model" umm can't wait..
They have been out for a while here...alot of these small cars are for markets which have very big population compared to Australia small 17Mil people....which is why they make alot of sense. I probably prefer the EK wagon Sports, but then perhaps you guys or Australia haven't come around to the styling or concept of small cars yet.
There will always be a Colt model and was always going to be revived, it is one of MMC pioneering models going back 1962 IIRC. If every maker killed off a model because of poor sales or design of one model we wouldn't see anymore of them...falcons, commodores etc...
Shell, I beleive the turbo version is the concept Colt Spider and the Colt Evo but it may only be primarily used for rally.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
