How have you run it in / what has been done in those 6 hours? Also, you need to do the test hot.
You have to load the new motor pretty hard to bed the rings in quickly and properly, doing it on the dyno is best and only takes an hour-ish
The other question is.....what were the measured clearances post machining and do they match the specs for the piston and rings
The first hour or so was not on a dyno, but 2 of them were on a dyno and it was pushed hard enough to get tuned.
My suggestion would be, even with 6 hours on the engine already, take it back to a dyno and give it a good high load run in, then test again when warm.
I've learned through experience that fuel glazing bores is very easy on a new engine but both times it was saved by pushing it harder. You just can't get that sort of good load on the road
Thanks for the suggestion of being on it. As the car has a break in tune, I went and hit 10psi a few times while driving, drove it kind of like a jack ass for ~1.5 hours, did another test, and all 6 cylinders were at/just below 125PSI. I took photos of it this time as I only my memory to remember seeing 150psi.
As for the ones that were low, my battery is kind of shot and dies pretty quickly if not charged, so I'm going to assume I just didn't let them build up enough compression or the battery didn't have the power.
The 150psi for #4 is definitely odd, but having no photo proof, I'm just going to make note of it. I'll retest it again when the car is cold to see where things are, but everything is insync now so 🤷‍♀️
No. Test it warm. No-one cares about cold compression results.
Have another battery handy that you can jumper on to make sure you can complete the test.
100% there is no point doing a compression test without an excellent battery.
Per what GTSBoy said just hook up a good battery with big jumper leads, running the starter for the compression test takes a heap of juice and is likely your main problem in the first test.
  • Like 1
On 22/06/2025 at 3:50 PM, MidnightR32 said:
Sorry if it wasn't clear, I retested right after getting home and the car was still hot.
Not only should you be testing compression with a strong battery, you should be putting a charger on it. These cars have pretty small batteries and it's possible to discharge them enough that by the last cylinder the starter isn't turning as fast.
Yeah, nah. Anyone not putting the absolutely largest battery that will physically fit (ie, NS70 X) is not thinking straight. the NS70 X is close on double the capacity of the "stock" unit.
And most chargers that most DIY people own would put bugger all power back into the battery between cylinders.
I've always done it with jumper packs/second battery connected. And that's on any car.
Because race car, and wanting the lightness. :P At least in an R33, putting a bigger battery in can at least help shift the weight balance backwards :P
    • I downloaded the apps (for windows) and Consult 1 doesn't have this function on it for the Consult 1 plug which I'm pretty sure all Skylines have. You would think someone would have a workaround after 30 years for all Skylines which have ABS.
    • Also, I don't know the actual ABS system on the skylines, but a sneaky thing could be a piece of electronic equipment that makes the ABS think you're moving, and then same piece can send a signal for a locked up tyre... Activate ABS without slamming brakes...
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
