  • Replies 223
Posted Images
I'd love to know Paul's secret to 450HP. I'm nearly there - with similar turbo (larger rear housing). Dude did you have an exhaust on your car when you got the 450 ?
This is 23 PSI - ( get no difference in power from 21 PSI upwards - tried 25 PSI today and 2 rwkw less - same dyno)
B-man, That was with a 3" exhaust and no cat, 45mm external wastegate. We found that pushing the boost much higher wasn't producing anymore power either, but we're unsure whether it was the turbo or the cams running out of puff. We'll be changing the cams soon, and failing that may try the GT30R.
maybe SST Steve can help here, is the reason Wolfs can make the power they do on standard injectors or standard GTR injectors because of the way they fire the injectors, Is it something along the lines of 2 squirts per fire rather then one (sorry no idea how to explain what I mean but I'm sure Steve will understand:) )
We are replacing the gearbox then of to the drags with a new set Street ETs.
Last year this car was running 411rwhp on stock pistons and injectors and ppl said that we were lieing then the car went on one of these ppls dyno and made 436rwhp.
its not still running stock injectors is it???
My sard 550cc injectors read 80% duty cycle at 320rwkw so 330cc stock injectors will be reading 120% duty cycle at those power levels.
Anyway highest i have got with GT30/40 0.70 comp and 0.86 rear is 322kw@wheels at 1.4bar stock internals at selectamaz dyno day which i havent got a graph for either.
car comes on boost hard at 4000-4200rpm with the 0.86 rear and lights tyres up 2nd and sometime start of third, so i hate to think how the power delivery with a 0.63 housing gives.
I got a graph from autosalon where it pulled 312kw@wheels indoors in hot conditions. The 322kw@wheels was in a 12 degree day outdoor dyno.
0.87 housing and 0.63 housing is quite a difference!!
I like it much better when i accelerate and i am actually moving forward and not just sliging along with wheel spin. Have you tried a bigger housing? you might see more power with more boost then as ur exhaust housing must be causing a restriction
I have now been convinced as to what people have been saying for a long time, Dyno graphs dont mean jack shit.
My car is currently in a Bayswater workshop in VIC getting some mods done.
The workshop in question has a brand spankers DD 4wd dyno.
This workshop together with APS built and developed a twin turbo kit for the LS1 engine.
On there own dyno the car made 460rwkw. On the APS dyno it made 510rwkw both times on RACE FUEL.
The car recently went interstate for a Holden vs Ford gig and won the dyno comp with a ridiculous 650rwkw on PUMP FUEL. Go figure.
The owner of the workshop showed just how easy it is to make a dyno read a lot lot higher than it should.
One example was to "manipulate" the dynos temp sensor for a higher reading in shootout mode.
The next example, and one I did not know about was that supposedly each car that goes onto the dyno is meant to be calibrated so that when the car is doing 100km/h so is the dyno.
He ran the same car twice in a row, one time with the dyno geared correctly and once with the geariing tweaked a tad.
The difference was amazing, the outright power wasnt that much higher, but higher nonetheless but the average power was about 20kw greater all the way across. Overlapping the two graphs you would think they were two different cars.
So to all the people who write "dynos are just a tuning tool and power graphs should be taken with a grain of salt" I 100% agree with you.
Yeah, I have thought about changing the housings, but I don't want to loose the nice spread of power I have. May try a GT30R on to see how it goes.
GTS-t VSPEC or Steve-SST,
which GT30 core do u have now, can u provide the CHRA number?
it might be worth your while to go up to an A/R .82 exhaust housing.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
