WERD, thats what I meant on the previous page by you live and learn :D
Half your luck..im doomed to repeat my mistakes for all eternity :Oops:
The best i have been able to muster from my car so far is mid 180rwkws at 8psi before i run into probs. Ive been meaning to get to Calder for about 8 weeks now to give my car a blast, was never too keen until i noticed 2rismo getting some good times with the Whiteline setup so thought id best give it a go.
I dont give a stuff what time i run as my 60ft is likely to be 2.5+seconds. As long as i have a good trap speed ill be happy as im interested more in how my car accelerate from 60 to 200km/h then from 0 to 180km/h :(
  • Replies 223
Posted Images
I have to say.... SAU has gotten very hostile lately... There is no more friendly rivalry, its taken a turn for the worse sad2.gif
Lets check the attitudes at the door eh?
How about we get the same tyres and send them over to each other
Paul as long as you fork out the $$ for the nittos and send em over to me after your done, as i am about to fork out alot of cash on some new 18's :D
On radials at Calder park is really pointless as that track is preped for sticky rubber if prepped at all.
Paul as long as you fork out the $$ for the nittos and send em over to me after your done, as i am about to fork out alot of cash on some new 18's :P
I'll be running Street ET's, but not I'm not going to send them over to you:D I agree with the track preperation over here street tyres are a waste of time.
I'll try and post a time up soon, just need to replace the clutch and gearbox.
any ideas wat sort of time i'll able to run? i just got my car tuned and got 258rwkw. i also have a 50hp shot of nos. just got some slicks for my 18's but arent drag slicks but guess they have to be better then the 205 street tyres i used last time
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
