So it looks like the 18th & 19th September at Phillip Island. Its a big ask but if Geoff and i get our hands dirty then im a chance. As soon as the mechanics fix my door we can get started on getting the thing running again.
And im being serious, does anyone know of a cheap daily driver getting around, Say under 2k.
  • Replies 218
Bring it on mate. I'll show you why the army trained me as a rapid combat repair specialist. As the saying goes "It doesn't take me all day to do a days work"
I'm now in the process of ensuring the turbo stays tight and getting the brake pedal height adjusted so the new MOMO carbon racing pedal set is perfectly positioned for H&T. Might even pull the master cylinder out and the calipers and service them all.
Roy and Geoff - Let me know when your getting into it and i'll be happy to lend a hand. :bonk:
I dont hink i can supply enough Real McCoys to quench your thirst :alcoholic
Any help would be great, dont forget to bring your car, as an RB26 might be going in and we may need a few odds and ends off your car to get mine running. Troy wants the RB20 replaced, Roy wants an RB26
Roy vs Troy , who will win :fight!: ...truth is its not really up to us, it depends largely on circumstance and where things fall :P
*shakes fist violently at Roy for taking up too much of Geoff's expertise*
Maybe the two of you can help me with my RB25 when it lands in a month or so.
When are the Super Fun Happy Slider crew going to take on Team Wang... a bit of healthy rivalry is good.
Your GTS can go up against me, you will only have to last more then one lap and they will have me smoked :goddam:
Do you need a nice TD06 for your RB25 :P
Shan we'll be done well before then mate. All help is welcome too Chris. We were a good team Saturday night :P. Without your comments I would have taken heaps longer to start bashing the wastegate with the hammer :D
Hammer...why im outraged...how dare someone show my car so little respect. Oh actually its not like you dented my door and punched my sump in or anything?!?!?! :slap:
The plan is hatched, just have to suss when the door is getting fixed and see if the spanner session gets done before or after. Im thinking before otherwise i could be waiting to late in the month.
I found the RB74/Comp2 combo great at Wakefield, no real issues all day and I did almost 90 laps. I'm using DBA4000 slotted rotors front/back on my R33 GTS-t and they weren't dusty at all. They did squeel under light braking but were fantastic... when hot. For my 5km daily trips they were overkill so i've gone back to some cheap 2nd hand standard nissan pads which... don't have any bite but do work well enough from the very first stop.
Sounds like PI is quite a high speed trap... I think I need atleast 5 pairs of underwear for the day going on the speeds you guys were doing. In the wet you would have had to drag me into the car :P
Yep, get it done early rather than later. I imagine the people involved could take quite some time to do your repair..... unfortunatly.
I'll be sure to bring along the cheap burbon.
Oh and piss off you aint getting any bits off my beast.
Do you need a nice TD06 for your RB25  :D
will a TD06 25G plus custom lowmount manifold, wastegate and hybrid intercooler setup do :P coz that's what I got sittin in my garage atm waiting for the engine and a PFC... got the PFC tuning software but no PFC lol
btw nark just got his ceffy so the Slider crew will be out in force soon.
I've just ordered a Misfiring system by Grid for the setup I'm doing... hehehe while all u wangers are lagging I'll be put-putting whenever I shift :P
LOL... with enough corner speed you dont have to worry about lag, its only those wearing skirts and high heels who tippy toe thru the twisties that need anti-lag :box:
What do you mean by lag? At a place lieke PI you wont have to worry, i found with very little chance for practice i could drive around the poor boost response of my turbo setup. I have jack all lag, but pretty weak boost threshold.
As for while you are cornering, ppl that know way more then me have my car setup so it turns very nicely whilst im on the throttle (feathered not to the floor) so power delivery is nice and progressive on corner exit.
A place like Winton, ummm , forget about it. I think any mildly modded Skyline would be frustrated around there as there isnt too much opportunity for wide open throttle blasts.
I know I sound like an opportunist, but umm I've got a spare set of RB74s. Umm does anyone want to buy them? :P
Depends how much meat is left and how much you want;) Front and rear?
a misfiring system helps you coming out of corners too, not just on wide open throttle blasts... basically it evens out the response of a car, giving it the best of both worlds, speed of a turbo and constant response like an N/A (which I'm used to).
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
