Rez's R32 GTS-t Type M... presentable version!
  • Replies 322
Nice car!
(I only like it cos it has a purple front on the stereo) :)
I'll get a night shot of it all lit up... you'll love it even more then. So whaddaya think of the knob? :P
Justin,
a couple of years back I drove to Kyoto...IIRC the drive was somewhere between 3 and 4 hours, but that was 5 people, plus luggage, packed into a Nissan cube with 89 PS of raw power and a max cruising speed of around 80mk/h, less when going uphill :):P:)
I imagine, in light traffic and with a heavy right foot, you guys could easily do it in around 2 hours or so....
Justin,
Mmmm, interesting... Troy, what do you think?
Dave, I've been quoted anywhere as long as 6 hours!! ;)
but that was from my place to Kyoto - no Osaka. Depends on the traffic really - going there took a lot longer (as I recall) 'cause we got caught up in traffic around Nagoya...
As I said before, I highly recommend you stop off at the Nissan Prince museum in Nagano - it's on the way to Yamanashi and well worth the visit...it'll break up the long hours on the expressway too....
if you give me the post code, or name of the area of where you're living now I can run it through me Nav system and get an accurate time/distance report from here to there/there to here...
I think the six hour estimate assumed you were driving with Miss Daisy :) RB powered rocket ships (and Evo's :P) should be able to do it much quicker than that :)
Justin, arghhh... traffic depending, it took me 4 hours to get to Suzuka during last year's F1 final but that wasn't taking the highway and there were heaps of traffic. But nice traffic...I pulled into a convenient store just a few kilometers from the circuit and there were a few F40s, 360, Lambos, Porkas also going to the race but stopping for a break. I managed to get some attention when a few French Rally fans came over and asked if I was a rally driver :):D:D (taking the back roads the car was very dirty and it rained heavily on the way over, not to mention my mate and I were in our F1 Malboro Racing shirts) ;)
Now in comparison if I took the highway heading to other places...it took me 3 hours to get to Hiroshima with light traffic, or 4 hours to get to Takatsu Snowfield North of Gifu or North to Japan sea - Amanohashi 2.5 hours. By right you should be able to get to Tokyo in 6 hours but not with Japan's traffic...10 hours more like it, but where Dave lives I think it is still quite rural...I still say 4 hours including short breaks or 3 hours nonstop.
Dave, are you talking about that interchange North of Nagoya/South of Gifu? If you take the wrong lane/turn you end up doing a big loop.
stock?
how much are the mirrors mate?
oh and less talk more pics ;)
Price as bought in Japan (ie: no freight cost) A$300.
Heres another pic... and it ain't pretty. This view will change soon enough:
looks like my engine bay. (including the APEXi pod) - are you going to box that up?
Evo_Lee has boxed his air cleaner up quite well, with a new "SuperAutobacs super induction air feed suction pipe"... and seeing as me and him are unofficially competing with each other with mods (he's leading - trust me ;)) I might just try and box it up and put a cold air feed in too.
Justin, if I still had the factory airbox like you do, I would have converted it to enclose the pod.
The one I have now is a WRC airbox, but look through the books I passed to you...I'm sure you should be able to find some airboxes in there.
Are we competing...I maybe leading but your car is still lighter, more so when your carbon bonnet goes on...yikes!
come on Dave, you've secretly got a turbo hiding under there right?
plus don't you have a set of TE37, reduced unsprung weight!...if you take out the spare wheel, jack, rear cardboard, carpets, babyseat etc you should be able to run against Justin...would certainly be an interesting test too ;)
hehehe, the only way I'll have a "turbo" under the bonnet of my GT-V (anytime soon) is if I borrow the wife's hairdryer and duct tape it in the engine bay :D :D :D
I dunno - stock 200PS RB25DE GT-V Vs slightly modded RB20DET GTSt????
...the GT-V is slightly heavier than a 25GT (due to the extra GTT parts)...I've wanted TE-37's for a long time, but a set of Work Emotions came my way and I couldn't say no. Isn't the R32 GTSt lighter than the R34's anyway?
Nah, a few mods to a the RB20DET and Justin will leave me for dust ;) Still, be an interesting race though :D
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
