after removing the rear blades from my gtr turbos after only 700 km at 1 bar
thought that maybe a pair of s13 sr20 turbos(they supplly 170 rwkw pretty easy easch) ... which are cheap and have the same manifold pattern should go onto a gtr motor..
has anyone done it or are they too big for the gtr motor to spin
is it just a waste of time in the end???
and does anyone have a sr20 turbo floating around to see if it fits????
pete
https://www.sau.com.au/forums/topic/50396-do-s13-sr20-turbos-fit-a-gtr/
The dump pipe bolts are different between a t25g and gtr turbo, also t25g's aren't good at all
in fact they shit
and for the extra lag you'll receive from running 2L turbos on an effectively 1.3L pumpage, it's not worth the time and money
Is your engine actually alright?
I mean, in most cases I have seen where a GTR turbo has blown the ceramic wheel.. there are signs of ceramic in the bore.
Need to get the mini camera out and check it before planning anything alse.. full rebuild may have you saving a bit more :P
How can it get sucked back in thru the exhaust valve. When the exhaust valve is open the piston is moving up the bore diplacing the burnt gases. When the inlet valves are open the piston is moving down the bore suckling in the fuel/air mix.
So i doubt that something in the exhaust will get sucked into the engine...could be wrong though
don't know mate... the more i think about something, the more I can convince myself that this may be the case lol...
I don't know if this is the case, but with intake / exhaust cam overlap, a small amount of exhaust could be 'sucked' back in?? Therfore, if turbo goes kaput, part of ceramic wheel could be sucked back in?
I don't know - like I said someone on the forums said this and I was sceptical as well
Need to get the mini camera out and check it before planning anything alse.. full rebuild may have you saving a bit more :D
Hi guys, I have seen 8 X RB's with ceramic turbine failure, 2 X GTR's, 3 X R33 GTST's, 2 X R32 GTST's and 1 X R34 GTT and none of them had any ceramic anywhere other than in the cat. There wasn't any in the turbine cover or in the dump or in the engine pipe, it was all in the front of the cat. Blown there by ~200 cubic metres per second of ~600 degrees celsius exhaust gas, that's better than my Stihl leaf blower. :wassup:
Maybe if you were spinning at the time and the engine turned backwards, you might get some sucked up into the manifold. Of if you where starting the engine at exactly the time the ceramic failed and it coughed and ran backwards. :headspin:
I don't think so, Tim :rofl:
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
