Yep increase in torque, also..
Viscous to Helical LSD
Different front bar
Two tone colour steering wheel and gear knob
Aluminum pedals
Darker rims (more GTR colour)
And i think that's about, altho i always forget something when i list the differences :D
cheers.
  • 1 month later...
The Series II’s also have a different turbo, Garret with metal compressor and steel turbine. Boost is set at about 900kpa and I believe the ECU is different as well.
Instruments have silver faces that light up orange, oil press and boost read in kpa vice kg/cm.
Center console is painted a bronze color and has the same radio options as the later GT-R. Shift boot is different and the shifter has about 10% shorter throws.
A good upgrade for Series I GT-t’s is to put a Series II shifter in as it is almost identical to the NISMO one and costs less.
Also the cover for the three gauges in the center has a better finish on it, more like the rest of the dash as does the center vent assy with the hazard button.
The power mirror controls are different as well. And the glove box does not lock.
  • 3 weeks later...
ummmm
isn't 900kpa like 9bar?? that isn't right,,
on mine , car boosts up till 0.75-0.8 bar approx (10-11psi) (car is stock standard),,
also found out i "used" to have fog lights!!!! but they were removed because a c-west front bar was fitted in japan,!!! doh!!!!
also!!! there was a factory option of "cup holders" at the rear of the center console!! under the ash tray,,,
i don't have an ash tray or cup holders,,, just a plastic cover,, for both... hehe,,,
is ur engine bay bayside blue or is it a really dark navy blue (almost black)??, mine is painted the dark colour, ( so is demon dave's r34) ,, i can't see y nissan didn't just paint the engine bay blue,,,
still,,,,,,, Bayside Blue rules,, :D
Afro
ummmm
still,,,,,,, Bayside Blue rules,, :)
Afro
Sorry about that I meant 90kPa .......extra zero in there.
My engine bay is dark blue/black. I think the 2001 cars got body-color engine bays.
Funny thing is all the white, yellow and red cars I have seen have body-color engine bays, but the silver and light colored cars had the light grey engine bays regardless of year.
ya its really annoying having the dark coloured engine bay,, you wouldn't believe how many times i've had to say "the car was NOT black before!, the engine bay is Meant to be black!"
lots of people think that the car has been re-sprayed blue....
have u compared ur car against a series I?? is there any difference in performance? (acceleration/power etc etc)?
Not many R34 GT-t's (only 3 I think) on Okinawa so I have not had a chance to "compare" mine against any others.
  • 4 months later...
hey eharrald
can u confirm that the series II r34 has the metal compressor wheel??
is there a way of telling from the outside of the turbo???
do you know if there is a different clutch kit used from the series I??,,, since there is more torque in the series II (i know 20Nm isn't much,, but still u never know),,
i need to change my clutch and need to confirm,,,
thanks
Afro
  • Like 1
hey eharrald
thanks
Afro
Hey Afro.
If you wanted to be certain your turbo had the metal compressor wheel you could do 1 of 2 things.
1. Take out the turbo and physically have a look or
2. Pull of the heat shields and look for the stamp on the turbo. If it says Garrett then it is metal wheel, if it says Nissan then it is nylon.
As for clutch, I'm not too certain as I have the tiptronic box.
oh ya just remembered,,
the series II instrument cluster ,, i.e speedo, tacho, the 3 guages etc all light up an amber/orange colour,, where as the series I lights up white,,
the A/C display still lights ups white on mine
were the sedans given all factory options (like a Holden calais equivalant)? i notice alot of people asking wheather or not they have a S1 or S2, did nissan actually call them S1 and S2 or is it just factory options? Also, why are there alot of variations of the skylines. ie: the 1998 r34 GTT sedan i have has 'skyline' in individual letters across the middle part of the boot where as some had skyline intergrated into the lower bumper. Another thing is that the sedans only GT shields on the front fenders, some have a GT-T badge on the back boot - below the right light. The interior instrument cluster and optional 3 gauge pod has amber lights (from what people are saying, its S2 that had them that colour but 1998 is an early r34 year so when did S2 skylines start to come out?), the rear seats have there drink holders and ashtrays and the driver/passenger have there own drinkholders. Does the vehicle ID plate state if its S1 or S2?
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
