I think this is the new craze because everytime i pick up a car mag i see at least one car with a flatmount or V-mounted setup. At first i thought this was to reduce piping and save space, but the lack of airflow would not make it worthwhile although its true that the engine would recieve better cooling. what do you all think of this setup?? i think ill stick to a front mount..
https://www.sau.com.au/forums/topic/51234-v-mounting-intercooler/
There is a curve piece that you put between the front bar opening and the cooler. so that the air going through the front bar gets directed up through the cooler then out through the vented bonnet.
would actually have better flow than fmic because theres nothing behind it blocking the air.
also for shorter piping too.
Ahh "V" mount, actually a ">" mount, with the intercooler at the top (usually) and the radiator at the bottom. The idea is that they both get fresh air, unlike an FMIC where the radiator gets air already heated by the intercooler. The intercooler exhausts out through the bonnet and the radiator exhaust (as per standard) around the engine and out under the firewall. It also shortens the intercooler pipework considerably, in fact if you do it right you can almost mount the intercooer straight onto the turbo and the inlet plenum.
Usually to mount them in the ">" formation you need;
1. to remove the radiator support panel
2. a bonnet with a large vent
3. a suitabe intercooler
4. a suitable radiator with special radiator hoses
5. a radiator water header tank (to get the air out, as the radiator is mounted lower than the engine)
6. many hours of fabricating brackets, mounts, pipes, ducting as nothing would be off the shelf.
Have I turned you away yet? :rofl:
Have you looked at using one at all SK, is there real benefit????
The SuperTourer uses a similar concept for its water, engine oil, transmission oil and engine air inlet. They are all staged so that each one gets fresh air ie; not preheated by another cooler. The V8Supercar is similar but not as sophisticated. Works a charm but it is really a pain in the ass to engineer and fabricate, and it makes simple maintenance a real chore. Like try changing a radiator hose :Bang:
In an extreme racing situation it is certainly worth doing, but on a road car? Personally I think it's more for "rice" than anything else. :)
the idea of it is that it gets better air flow so it couldnt by its very nature suffer from heat soak.
In a race application maybe so, because your not stopping.
But out of interest, what about say normal city driving, stop start etc? Would it not have more potential to heat up then? Or is this a problem anyway as the pipes themselfs heat up?
I dont know, hence asking the question.
Without airflow it would be a waste of time, the hot air from the radiator goes straight up into the intercooler. With a front mount thta simply doesn't happen as the engine fan draws the radiator hot air away from the FMIC. Which brings me to the next point, where do you put the fans?
as far as the intercooler is concerned the V setup is better as hot air rises, and all the hot air will go out the top of the bonnet wherre there's a vent above the IC. So even while the car's stopped, theoretically it should be better or at the least the same as a FMIC.
Yep, but the hot air comes up from the radiator and goes through the intercooler and out the bonnet (ie; hot air rises) On its way though the hot air heats up the intercooler. That never happens with a FMIC, the radiator is behind the intercooler and the engine or electric fan sucks the hot air from the radiator, away from the intercooler.
In a > mount in traffic or stationary, the intercooler will quickly get to 90 degrees, which is the temperature of the air coming out of the radiator. It will cool down once you get moving, that why it is an OK setup in a race car. But a waste of time and money in a road car.
Oh and you should see the damage if you have a slight front end tap, makes a real effenn mess. :D
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
    • Yeah the rule of thumb with an LS is 7psi per 1000rpm. That is decidedly not enough at 6800rpm. I mainly looked for the scenarios where knock started to be picked up and it was later in the session when things were hotter, and oil was thinner, and the pressure was lower than it should be. (i.e very horrible). I am hoping with thicker oil (I was running Penrite ten tenths 10-40, the manual specifies 10-30) that does not leak that it's much improved at that time!!! I am using Project Mu Club Racer CR pads. I'm also using the Project Mu 335C fluid. The symptoms imply that it was fluid that boiled, but no bubbles seemed pretty weird to me when I bled it today. I want to try Castrol SRF as it has a much higher wet temp but, well, I have new Project Mu fluid lol... so I should at least use that. The pedal on track was really noticable. It went from basically normal feeling to instantly near-floor. The car did pull up as before, it was just very much nearly at the floor before the brakes engaged. At that point I pretty much decided the day was very done, it did *kinda* come back during that very slow cooldown lap into the pits. Felt perfectly fine driving home.
    • f**king around with the bro
