74 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
GTS-R is a homologation special like like a Cosworth RS-500, and I wouldn't call that a sports car.  Sports cars are small, light and have an emphasis on handling
A GTS-R weights under 1400KG's if its standard.
around the 1350 i would say at the most.
you cant class em as a GT, no chance in the world.
They were the car before the GTR, and most certainly held thier own
With all the GTS-R add-ons there were a nice change from the normally dull RB20
  • Replies 49
haha, just think they can easily be confused with the aussie cars even though they are quite different throughout.. the "non-educated" motoring population wouldn't know the difference
I get people asking me alot what is it? i didnt think people clicked it was an aussie 31, i get more the impression people see it as that sports coupe from japan. I've had some older blokes come up to me on a few occassions and have a chat purely because they like the look of the car, the shape and the fact its a mean, well designed car. A Hr31 gets you lots of looks, people scratching their head, thinking- whats that? Power wise.. basically the same mods done to a r32 to get it up and going- they both have rb20's... I voted GT
  • 4 weeks later...
yer, mine was 1.4 exactly... that was with the 25 which is around 30kg's heavier or something from memory.
that was with me in it too... but mine had a lof of the sound deadening ripped outta the boot and stuff, you can see the scrape marks under the rear seats if you pull em out
My '88 GTS HR31 with ~30l of fuel was 1440kg.
My '88 GX local R31 with ~30l was 1280kg.
All the extra bracing, big doors, electric stuff, sound deadening, IRS rear end, spoilers and the fact everything seems to be that bit plusher than the local one (ie plusher dash padding, door trims, much nicer seats etc) all seems to add up.
Since I'm not stripping it out to go faster, I'll just have to get more power :(
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
