Hey,
Well i think it time to add an ecu to my list of mods, and after doing abit of research wolf3d looks like the best opinion for the price it is :) But i still got a few question so if anyone could answer them it would be very helpful
1.I was told that the PLUG in PLAY Wolf3d does not do anti-lag and rotational idle is this ture?
2.possible to have antilag and rotational idle on a switch (on/off)?
3. I know with wolf u can hook it up to ur lap-top, whe u buy the wolf does it come with the ecu to pc cable and all the software? and can u view data in real-time while driving
4. What is the average price for the newest wolf3d (i havnt been able to find this yet) and install and tuning it with antilag, roational idle (if it can have it) on a stocky r33?
5. At the moment im running a Greedy ebc, is it worth removing it and just using the wolf to do the boost or should i keep it?
Thanks Mike
p.s yes paul i know antilag will kill my turbo :D
https://www.sau.com.au/forums/topic/51622-wolf-time/
i can answer first question - i know it can run rotational idle :) Pauls car runs it occasionally - when steve wants to annoy him :)
nobody really runs Antilag on the street ...... only on the track ..... have you thought about how much it would cost to run antilag fulltime? :D
https://www.sau.com.au/forums/topic/51622-wolf-time/#findComment-1021095
Mikey - im gathering you've never seen ca rthats running Antilag - cos if you had you'd know that its hardly wank factor ...... nos is wank factor ..... antilag just makes ya car sound like popcorn.
https://www.sau.com.au/forums/topic/51622-wolf-time/#findComment-1021109
wank factory??? - how much to they sell a wank for?
rotational idle and antilag are two terms that your car should not come into contact with... i like the words advanced driver course first... also does the list of mods have a dump pipe on there or have you done that already?
https://www.sau.com.au/forums/topic/51622-wolf-time/#findComment-1021116
Sssssh i want to see the fireworks :Bang:
:D
https://www.sau.com.au/forums/topic/51622-wolf-time/#findComment-1021120
RiaZ, pretty much everything is getting done at once, dump/front, hiflow cat, ecu, fmic possible plenum, z32 afm, fuel pump, and maybe injectors.
i want to get the ecu in 1st, as i had a dyno run at hyperdrive and the car was pinging at 0.6bar and didnt make that much power
https://www.sau.com.au/forums/topic/51622-wolf-time/#findComment-1021125
hey thanks everyone for your great replys, i ask a few simple question and got only a few replys that help thanks niz and b_real
for the rest of you how about if u dont have anything to help me dont post anything at all. advance driver course? yeah good idea seeing as i have crash my r33 how many times? and that i drive like a tottal ****ing hoon 24/7
FFS, DONT REPLY IF U GOT NOTHING TO SAY ABOUT WAT I ASK PLZ!
https://www.sau.com.au/forums/topic/51622-wolf-time/#findComment-1021235
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
