is now for sale at unique autosports
Looks like the old fella wants to get rid of it, certainly looks awesome with a lot of work done.
Asking $130,000.
check out nismo.com.au > cars for sale > GTR for more info
1 Please :uh-huh:
  • Replies 48
Says 350KW at wheels so yeah i'd say some DEFINATE mods on that baby!!
Question is where would you park such a car? Even in Little old Perth i would be worried bout parking it in the street or gettiing stone chips on sunday drives that ruin that beautiful paint!
Don't get me wrong that is the stuff that my dreams are made of but i would be sooo over protective of it!
I have seen some R34 GtR's come through the Prestige Imports private auctions a while back going in the high 90 Grand mark... after you spend money getting it looking that nice you wouldn't be too far off...maybe about $5000 saving?? sounds like a big saving but not when your dealing with $130,000!!
Originally posted by XCUZME
pity the wheels are a bit homo, otherwise f'in hot.
saw that wheels in real life, and i must say that those actually look rather okay than homo... just each person's taste i guess... but i HATE those big chrome wheels that r ugly assssss
That is hot!!!!! Those rims i think are Veilside ones, i think they look awesome. Im not sure if this is the one but a GTR in NSW has Nismo RSR-581's which would look like the set up he has there but then again his could be hks2530's!! Farkin awesome car none the less n i dont think its too overpriced when compared to a good untouched one, thanks for the pics BY BY
they are manaray wheels, we wanted them for the supra that never happened. good luck finding those style of wheels for sale in Australia!! but if you do, there big $$$
This car is on the cover (& featured within) Zoom issue No:41 Have a read of the article & see if you think it's worth the $$$.
Lots of Nismo / HKS / Apexi parts. All areas modified, suspension, braking dept', the lot! A claimed 11.36 1/4 when the article was written (303kw @ wheels).
Add up the total outlay to the build a similar car & you’re in for a rude shock! Sure, nothing is worth what it costs to buy/built but even so this is a very impressive package.
The wheels look a bit 'Homo'.......WTF? So just what do good-looking wheels look like then?
Kabab,
:lol: You gunna' have yarself some reeeelations?
YuMMO! maybe in my next lifetime :D
a supra owner once commented to me (don't know how relevant being a supra owner is to whatt im about to say) that the R34 GTR is seen as the worst GTR by Japanese enthusiasts...i think this information was passed on to him by a Japanese person but im on the thinking that he's either agreed or chose not to comment on that argument.
does anyone have any comments on this?
as far as im concerned, it is the best...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
