Hey ppls.
Well, I'm now starting my next project after the Radiator guides.
I'm going to be making up a bunch of aluminium pipes from the Air Flow Meter to the mouth of the turbo.
Reason?
It is well documented that at boost levels of around 0.9 bar, the standard rubber pipe can suck closed, resulting in everything you would expect to happen with bugger all air getting into the engine.
Also, in hot weather this phenomenon will happen easier as the pipe heats up and becomes softer.
Solution?
I'm making up a section of pipe that will 'splice' into the standard AFM to Turbo duct. You will simply cut the standard Rubber Duct and remove a small section of rib, then insert the section of pipe, then clamp up the pipe and reinstall the new duct.
Construction?
Mandrel bent pieces aluminium, in a raw finsih, TIG welded. No polishing will be done, but if you want to do it when you recieve your pipe, the aluminum is ready for it. There will be sufficient pipe at either end to give a good seal to to the air. The best finish will probably be either anodised or powder coated. I would recommend podwer coating personally.
Currently the R32 and R33 rubber ducts are down at the fabricators being prototyped, and I expect a sample of each back early next week (24th - 26th January 2005)
Not sure of the final price until I get the samples back.
The standard duct will not be able to be returned to standard after fitting the new section of pipe, but the duct will be such that it will be virtually invisible to the untrained eye.
They will fit in a TNT Airbag, so freight anywhere in the country will be $15.
Maybe if somebody in each state wants to be a distributor the freight can be greatly reduced.
So, who's interested??
Please advise your model of car.
R31s
Angry (RB20DET)
AnFz
Total R31 = 2
R32s
-Joel-
Sheepy
Predator
WazR32GTS-T
KICKIN (Ceffy)
FAT32
Jolinator
TurboX
26GTS
tkch55
sskylinee
Memph
Total R32 = 12
R33s
RedlineGTR
Robo's
Pinoi-Boi-r33
Riceline
B1 Mr_Fanny
Wolverine
Xr8Eater
gtrGhosTDoGG11
burnfest
SydnetKid (Stagea R33)
Jay95R33 (Stagea R33)
ICE12 (Stagea R33)
SKYBEE
|PRESA|
Trust33
tridentt150v
BLakniTE
SKYNUTS
lbfalcon
GOR33
Bobjones
CMS Drifter
knore
drewecrome
halz
R33 newbie
predator
R33_KRAZY
nacional
craz0
gts-wpn
LANFOH
Babia
r0ma
NZM.031
Zebbie
MYSTR33
Total R33 = 37
R34s
ME of course
Adzmax
Daz
Muz
Abo Bob
Coxy_
GTTR34
Neo_R34
CNBLOW
HKS34R
ascension
Total R34 = 11
Total So Far 62
BASS OUT
https://www.sau.com.au/forums/topic/51709-group-buy-afm-to-turbo-duct/
  • Replies 309
Very interested but I can't say for sure until I have a closer look at my intake and see how exactly my pod has been fitted.
But after the last group buy I can highly recommend Bass's work. Great quality air guide and lotsa communication as to progress etc.
Hey guys.
Regarding the location of POD filters and the like, I think with a simply modification to the filter bracket, any misalignment issues would be sorted out.
When I fitted my Pod filter (fully boxed off Mr. Plod) the location of the AFM was very very similar to the standard location.
Obviously when I make up the AFM pipes, I will put my standard Airbox back on to make sure everything is spot on.
Different AFM sizes??? Internaly they are the same.
Different Colour Silicone.... I might well be working with Shift Performance or somebody like that for them, so you will be able to request different colours. I'm making mine black with black pipes.
Also, I may be able to powder coat or anodise the pipes if you want to match engine bays, but obviously these things will cost extra and it's something I can only do if a few people want to do it (anodising that is). Powder coating will be easy.
BASS OUT
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
