Hey STAGE-A,
Let me know what settings you end up using with your eboost.
If you like I will forward all my settings it may help you...
SP1/GP1: 05/02
SP2/GP2: 15/09
SP3/GP3: 30/09
sen: 15
OBS: 16.5 PSI
AL: 15.0
bAR: 16.5PSI
*I WOULD LIKE TO COMPARE WITH SOMONE..
Had my SAFC2 tuned & my 100,000km service done the other day. While at it got the car dyno'd.
Pumped out 150.4kw atw, on 7psi. Only mods are SAFC2, & a 3" turbo back exhaust system (not split either).
Before SAFC2 was tuned it had 137kw atw, so made a nice gain from that being tuned.
Once l've got the air scoope through BassJunky, and a half decent filter i'll push the boost up to 10psi. Should do nicely for a daily driver.
Edited by -FUZZY-
Nice work fuzz,
I just put my split dump and high flow cat it already had fuji cat back so now the whole system is 3". Put on the FMIC today and i tell you what the car feels so much quicker.
Next will be SAFC 2 and tune, still waiting on scoop from bass junky, then pod in enclosure or just high flow panel
Hi Guys, thought id jump on and tell you i had my 260RS serviced and run yesterday. They dropped the front shaft and ran it in rwd, it managed to run 233.6rwkw, so through everything ive been told, around the 220awkw mark.
Reading back through the last few pages and even after seeing the dyno chart on RS4Stagea, im a little intriuged as to how accurate this dyno you went too is, either that, or your motor isnt as stock as you may think when compared to the other stageas running around 150-160kws, 40kw is a large jump, especially in comparison to my 260RS running 233kw with the rb26. Just my 2c worth!
Hi All,
I have 1997 RS4 (Auto)
- GCG HiFlow Turbo
- Hybrid FMIC
- Walbro 500hp intank Fuel Pump
- Turbosmart Eboost EBC 7psi 10psi 14psi
- Turbosmart FPR (Street)
- K&N Pod with cold air induction
On a Dynodynamics 4WD Dyno @ APC in Brisbane
203 kw @ all 4 wheels! 3rd gear :sorcerer:
made roughly 100kw @ 3000rpm :P
made roughly 200kw @ 6000rpm :O
Have no issues with factory ecu (maybe its chipped?)
Dont think I will bother with piggyback or aftermarket ecu's
The guys at APC rekon with a Haltech I could get in the 250AWKW+! :(
Need about $3k for that though....
Wade
Do you have a dyno graph of the A/F ratios to post up?
Mine went R&R mapping as soon as I went over 125 4wkw.
:O cheers :O
Yep, 125 4wkw on the standard turbo and 160 rwkw on a GCG high flow sounds somewhat logical. That’s why I would like to see the A/F ratios on one with 200 4wkw and a high flow. The extra 40 4wkw is very interesting and has to come from somewhere.
:D cheers :yes:.
Looks like mine will be hitting the dyno in 2 weeks so i guess we will see how i go.
By the looks of things i should be expecting around 130 4wkw?
Mods: Bos Split dump, Bos Catco Cat, Fuji cat back, ARC FMIC evrything else is standard im pretty sure.
Getting mine dyno'd on saturday (my bro-in-law is a member of the magna club thats got a dyno day at GWW that day).
Will be interesting to see the results...
my mod(s) are fairly controversial - had to replace my turbo so i've now got a nice garrett GT30....but everything else is pretty much stock. Fortunately that includes the exhaust so that kept boost levels and airflow down (strangled really) but its not a bad thing because it means the stock ecu/injectors etc. still cope just fine and also intake air temps are still handled well by the stock r34gtt intercooler.
On the plus side, the car does have slightly more lag but considerably more power overall (and still pretty responsive) - and I now use 1L/100km less than before without changing my driving style. Its not what people predicted, but its good news for me...
...which is why i'm really keen to see the AFR graph on saturday :ninja:
will definitely get a scan of the graph and post the result as soon as i can on saturday. :laugh:
Hi all,
I got 197 at the rears with 7psi and a rev limit of 7000rpm. It looked to pull hard on the graph and still had plenty left in it. I am hoping to run it up to around 8250.
Its still got a pretty basic tune atm, need more dyno time. Will keep you posted.
Cheers,
Ken
So pretty much the same mods as me, i just recieved my Z32 AFM today :P wont be installed for a while though still need to source a SAFC for a decent price, and i wanna get my fuel pump and FPR then ill install it all at once then get it tuned.
But ill be hitting the dyno 9th of sep.
Looking forward to seeing your results EGA 41T
Hey guys, some good figures coming up in here, NZ has some really nice stageas, there is an Autech S2 Stagea cranking out 400+KW at 4 wheels, RB26DET tho, and a few others with a little bit of a smaller figure.
I have been able to get my S2 up to about 185rwkw - only rw as I have a RSV, not a 4wd model, it does great skids too! :blink:
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
