thanks fellas, the 22psi run didnt get much more power than the 18psi (another 40hp or so) so it looks like its running out of puff on the old t04z, it is a conservative dyno compared to some other ones in perth so it should crack 600 on other dynos if im lucky. looks like its turbo upgrade time to something huge that will make full use of the stroker kit in the near future and keep the Z for road use :huh:
the sound of it at 8500rpm is pure car porn :angry:
  • 4 weeks later...
I said it before, and I'll say it again...
Holy Snapping Ducksh!t Batman!!!!
Gonna hit the strip anytime soon? Let us all know when so we can come down and watch!
new dyno tune, results are 585rwhp on 19psi and 605rwhp on 22psi (didnt rev to rpm limit due to problems so still abit more in it)
ill post graph tommorow
Brad?
Is this for a Stagea or R33 GTST, because your user details list a R33?
Paul im running the 0.81, maybe there is a difference in hks vs garrett versions for power ;)
the dyno i used is very convservative too
lets just say the car is currently engineless and im planning on building a different setup and this engine go into a rwd track car. Not by choice that the motors out soo quick but some problems happened on the dyno and now the motor is stripped with pistons and rods etc all out.
oh i just love cars :(
Edited by overpowered
Paul im running the 0.81, maybe there is a difference in hks vs garrett versions for power :D
Brad, That's a real shame ;) I'd love to do back to back comparison's of HKS versus Garrett, but I'm guessing your on a T3 hourins, not T4 ?
hey thanks guys for the support, that engine will possibly be back in the stagea but not for a while, ill be running another engine combo for the time being.
Paul my turbo is a t4 flange (my manifold is from Trust and suited for a t78/88).
well, $800 later. was going to be a grand but they did me a good deal. can recommend Boostworx for sure.
exhaust manifold was snapped clean in half, replaced with same, busted radiator when I stopped the car in front of the workshop, replaced with slightly thicker GTst unit, new exhaust studs, redid all the intercooler pipes (lol they asked who fitted it hahaha - me ! dodgy home job) for me, all's running well, bar the RESTRICTIVE rear muffler.
Knew I should have changed it back over xmas. Will get an oval 3inch straight thru muffler, have the adjustable exhaust cam wheel fitted, and retune to 16psi.
Dayz special edition Stagea RS V Four,
89000kms, automatic, RB25DET engine, Attessa 4wd
Clarion stereo tape unit with 6-stack cd player
Clarion amp
Clarion 10inch subwoofer
Pioneer 260w 4-way front door speakers
Eclipse 80w 2-way rear door speakers
Black Widow 10000 car alarm
New Oxygen sensor
New 400amp battery
Penrite 5w-60w oil
Davies Craig automatic transmission oil cooler upgrade kit
Whiteline front and rear adjustable swaybars
Whiteline rear subframe alignment kit
Bilstein front and rear suspension shocks, with ‘lowering’ circlips, using standard springs
Bosch 040 fuel pump with direct battery feed at 13.8volts
Nismo adjustable fuel pressure regulator
Nissan Z32 Air Flow Meter
3inch JustJap stainless steel single dump pipe system
3inch Catco high flow catalytic converter
3inch cat-back mild steel exhaust system with restrictive muffler
K&N pod filter
Maxx’s Cold Air Induction box with direct air feed
BassJunky’s Radiator cold air guide
Hybrid dual stage Electronic Boost Controller, set to 14psi
Apexi 'hybrid' front mount intercooler with custom pipe kit
Apexi boost gauge
Apexi SAFC Super Air Fuel Computer
Apexi SITC Super Ignition Timing Computer
R34 GTT 17inch rims
Hankook K104 tyres, 235/45/17
Sliding Performance 360deg journal bearing oil/water cooled highflowed R33 turbocharger, rated at 250rwkw@1bar
Not Yet Fitted:
Volt stabiliser kit
Whiteline front castor kit
Maltech front and rear stainless steel braided brake lines
DBA slotted front rotors
Aerospeed adjustable exhaust cam gear wheel
Need To Buy:
Free-flowing open design 3inch muffler – current muffler is too restrictive
Retune to 16psi with exhaust cam gear wheel installed set to 4deg retarded, with Hiflow muffler, Id guess 220rwkw should be achievable
You are kidding! Mine did the same, it started to make exhaust leak noises a couple of weeks ago, which gradually got worse. So yesterday I thought I would tighten up the manifold nuts, they are the usual culprit. Been puting it off as the heat shielding is always a bitch to get off. With the heat shielding (finally) off I was amazed to see a cracked exhaust manifold, all the way around the log between #3 primary pipe and the turbine flange. I have never seen that happen before, and now I read the above.
I will post up some pictures tonight.
>_< cheers :)
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
