RS4S - Power FC - Blitz zorst - Greddy fmic - Hks pod - T piece boost control
150 awhp std ecu (surging and slurping)
173 awhp untuned pfc
194 awhp @ std boost - tuned PFC
206awhp @ 11psi - tuned PFC
Edited by RED513
There is a thread for Stagea Dyno charts in the DIY sticky above labelled "Stagea Dyno Results" .
Well after the sh1t-tacular results of sticking the C34 on the dyno I thought we might like to make a thread to post stagea dyno results in. ( or lack of results in my case !)
Any suggestions/comments are welcome ( positive of course ! )
116kw Stock auto s2
146.2 3inch turbo back, air pod, front mount.
138 3 inch turbo back, front mount, stock air box.
129.8 3inch turbo back, air pod, no front mount.
next will be with front mount, nistune setup, and new gearbox solenoids
ssshonky.. our results are crap.. 222awhp @ 12-13psi through a hiflow when people are pulling nearly that with stock turbos.. just about everyone was 100hp down.
I shall blame the 38deg day and the Haltech pulling heaps of timing!
Edited by bubba
first mods:
second stage:
third stage:
fourth stage:
fifth stage:
sixth stage:
seventh stage:
eighth stage:
issue being fixed on 6th january - adding stainless lowmount manifold, 4-pot brakes, engine oil cooler kit, wideband afr meter & oil pressure guage
expecting to see 250rwkw now Ive sorted out the rpm cut as seen on 7th stage
Question,
How many KM's are you planning to get out of that motor? and how often will you be driving the car?
Is it ever likely to blow up? (I'm unsure whether im asking stupid questions or not here) humor me though? :)
Thanks for the support- I was feeling hell emo ! I almost put a black fringe on the stagea so it could be Emo too. Well - To be honest its a good outcome from a bad dyno run. Loretta finally realises she really needs to chuck some $$ at the car to get it running to its full potential. I thinkk she is going to be happy with the results from essentially what she already has!
I compare it to an athelete getting fat and out of shape , with a bit of work he/she can be back to full potential - kinda the same with the Stagea
we wont know anything till the 5th of Jan - so stay chooooned for an update
MacDog- valid questions, but most tuners will be pretty sure to run a safe tune( Ie dont make it go too lean ) so in theory sure you will get more wear and tear from pumping more power out but as long as it does not lean out you should be ok.
Cool,
Next question, have any of you guys Blown up a motor?? :3some:
Question,
Is it ever likely to blow up? (I'm unsure whether im asking stupid questions or not here) humor me though? :3some:
hey mate. Ive had her for near 5yrs, and plan to have her for a further 15+.
sees the road every week, and the Hills every 2nd weekend.
sees the Hills very nicely indeed :D need a nismo speedo
the motor will be there for the time I own the car, she aint' gonna blow.
one day in a few yrs time I'll do the final stage of tune and complete the bottom end, but that'd just be for kicks not necessity
would expect 270kw once complete
also, I'll be self road tuning after the next dyno tune on the 6th january. adding in the wideband lambada sensor kit,
so my laptop can feed me the data while driving and adjust maps to suit.
cant wait tbh :/
Cool,
hey, my fist bike ping'd its face off. a gpz-250cc couldnt take all 115kg 6'8" of me :/
I had to rebuild my Fireblade many moons back due to glazed cylinder bores; caught it early, could have onsold without issue but that'd be bad karma
so I threw 12g over 4yrs into it and enjoyed every km thru the Hills. very capable machine that one.... 300 @10thou rpm top gear. often
never blown a car engine tho.
dont plan on blowing this one either, Im sure Ive done everything right along the way to ensure now that I'll be selftuning I wont f**k anything up.
ie the vehicle in a whole complete form can take it.
as it is the rb25 + gt3076r has loads of punch thru the twisties : will look forward to hardening it up a little more with the bottom end build and then she'd go like the clappers
not that it doesnt now, very bike-like in the Hills.
:D
  • 1 month later...
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
