  • Replies 103
Cool - Aiming for about 270-280hp on Stock turbs! You guys better stand back, I will overboost it if I have to (good excuse for a new turbs)
Will be looking forward to see your new install of the cooler Kym, and the output that you will be getting :D
Be sure to say hi if you come down...or up should i say :D
God Bless,
Nate
