Sydneykid,
Did you have any dramas getting the rear bar to fit? I cant seem to get mine to go even close - the mountings are about 35mm out?
Jash
Take a look at my pictures of the Whiteline bar and the standard bar, on the previous page. Where abouts is it "35 mm out"? If it is at the ends of the arms the links are, have you put the links on the outside or the inside of the arm?
Mine was a tight fit where the D bushes go around the bar, the U bend in the Whiteline bar was a little closer together then the standard bar.:cheers:
awesome work SK, love the info - I will definately be doing sway bars next then as, like you, i am really getting jack of the directionless steering and body roll.
Awesome that they are the same as GTR's tho, any idea what springs/shocks fit? I was assuming these would be the same as a GTR also... (I hope, then i can fit my HKS coilovers).
Christian
Prank,
There is a slight difference in the top of the strut between GTR and Stagea. The GTR is a little bigger and doesn't quite fit in the tower, so I've been told. So from what I understand just use your top spring retainer from the Stagea. And if the rear struts are off a 33 GTR the bottom mount is completely different, so they won't fit at all unless you change the hub carrier to a GTR or 34GTT type.
Cheers
Gary
It was where the U bends were. They seemed to be right in the spot where the bar had to be mounted - how tight was it?
Jash
Mine was a tight fit where the D bushes go around the bar, the U bend in the Whiteline bar was a little closer together then the standard bar.:)
Jash
Hi Jash, if you still have the standard bar, then measure across the inside of the U bend and compare it with the Whiteline bar. If it is not within 5 mm then it won't fit, so give Whiteline a call on 02 9603 0111 and they will send you a replacement. You can usually give the wrong one to the same courier to take back.
I think what happens is the Stages subframe is slightly narrower and when the jig is set up, the outside measurments are used instead of the inside. Since the bars are thicker that means the U bend is too small.
Hope that helps:cheers:
posted some pics(my gallery) of underside of 260 and scan from autech blurb showing handling mods..roof braces etc...this car is stiff.. no roll thru corners..suspension makes lite work of 1700 odd kgs...hard to believe its a station wagon...until parking at the shopping center..then the long wide load thing starts to happen ... its so farkin long
  • 1 month later...
The Bilsteins go in this weekend, so I measured the centre of wheel to guard heights as it is now;
RHS Front 395mm
RHS Rear 370 mm
LHS Front 395mm
LHS Rear 372 mm
I am thinking of around 360 rear and 370 front, so I will have to machine some extra circlip grooves. Maybe 6 at 5mm intervals.
Need some feedback from the guys that have already lowered theirs, please post up your centre of wheel to guard heights...........:)
Just rang King Springs in QLD and they actually recommended not using their springs in Stageas! They said the fronts are easy - but they dont have a spring suitable for the rears, and even manufactured ones were a bit risky in their opinion!!
So looks like Im a gonna take the advice of a few of the tune shops here in Perth and get the specific Stagea Tein springs sent over from Japan... been quoted $550 fitted which aint bad I suppose.
Just gonna go with stock shocks for now... in the series 2 stageas they seem a heap better - read somewhere they were upgraded for the extra output etc of the Neo6... and certainly seems that way having driven both series 1 and 2 stageas - much flatter cornering and minimal body roll in series 2. Will see how it goes and maybe get Bilsteins later on if I have suspension issues.
The quote was cheap, but i think it was because it was part of an overall list of work worth a few grand - so they are probably making up their profit elsewhere - they gave me that price alongside all my exhaust work and air intake and other bits and pieces, when I told them Id been quoted $600 to fit King Springs (which I now find arent ideal for rear spring choice anyway). Ummm - I'll check with the tune shop about a stand-alone price and PM u mate :)
Guy's,
I can get cost price for Teins, I am sure I posted it up earlier. I have a set on my car. They work well. If you need a set let me know. They are ex Japan though. Be prepared for a wait.
Cheers,
Ken
Cheers Ken & Brazen - I was looking at these on Tein's website last night:
http://www.tein.co.jp/swgdampe.html
About $1250 for the set + shipping, fitting etc - Ken, what would be the approximate cost price?
I have no idea whether this is what I want or what I need! But does seems like it has the right 'bits' (as far a my very limited research tells me) and it is a set made for Stagea...
I currently have the Whiteline anti-sway bars (as outlined in this sticky), 235/40/18s and the caster arm adjustment thingo... I still find that the car needs firming up - I like the 'soft' ride in a straight line, but still feel that it rolls and wobbles a bit when moving off the straight...
Tein's web site doesn't give a great deal of info on their stuff, so I wonder whether this set will be too firm, or not firm enough - though it would have to be better than the 118k stock shocks I would expect.
:D
Hi Tigerleo
Phoned Hanson at Xspeed who do all my work and he is happy for me to put up their quotes for Tein springs for Perth customers. As I said mine was cheaper coz of getting a lot of work done at same time, but his "Springs and nothing else" price for the Stagea fitment Teins are:
Tein S-tech springs $450 fitted
Tein High-tech Springs $650 fitted
But yeah - better to call him for a specific quote on anything you are thinking about - have found them really competitive and great service. Hanson was saying he is actually looking at buying a Stagea for himself, so sure to be the next Xspeed project vehicle (which you can gaurantee will end up on a magazine cover!) so itll be good to know my Stag work would have been researched and experimented on by Hanson on his own Stag a thousand times over! ;)
Also just for anyone looking at exhausts - Xspeed also have a special on at the moment for the Stagea specific fitment HKS Hi-Power 409 WGNC34 for $718 + GST.
http://xspeed.dreamhost.com/catalog/produc...roducts_id=1044
They have a shipment of these exhausts arriving in March.
Hope that info helps
Adam
Probably best to ring Hanson at Xspeed directly for specific inter-state quotes... say you got the price from "Adam" off this forum and just wanted to know an unfitted price with delivery.... Hanson goes out of his way - so if they do interstate Im sure he'll look after you.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
