HELP!!!
I've finally put the bilstein's in, but the spring hat on the drivers rear side is rubbing slightly on the tyre.
Apart from raising the car up (its on circlip groove 3 from bottom), is there anyway l can fix this? Its not rubbing much, so will l just wear part of the tyre away before it stops rubbing, or could things get worse.
not a good idea to add positive camber that will wreck your tyres assuming you are running it on the road.
what you really need is wheel spacers, or even better a different offset wheel to clear it properly
don't run it as is, rubbing the tyre is bad news
nooooooooooo
not literally POSITIVE camber
i meant as in adjust your factory camber arm to move it out a bit.
Not like +camber..my bad.
i mena, if its just lightly rubbing, a small camber adjustment might fix it
but like duncan said, a lower offset wheel will fix all
  • 3 weeks later...
my stagea has nismo s-tune suspension. is this height adjustable in any way? or can it be adapted to be height adjustable? im pretty sure it is damper adjustable, looking at the strut tops (there is a numbered dial on top).
Any help would be appreciated.
as in circlip grooves like SK's whiteline/bilstein kits? I will check it out.
Anyone have much experience with nismo s-tunes? decent suspension....?
Car got a few things from the nismo brochure it turns out - S-Tune filter, S-tune suspension, nismo clutch and nismo badging.
  • 3 weeks later...
just finished reading through all 25 pages and man do i have a headache :D
now forgive me for being such a n00b but there hasnt been much talk on
an actual set of coilovers for the stagea....anyone have any ideas?
i dont actually have my stagea yet, she's still on her way over from japan,
so obviously i havent had a chance to look under her yet. But basically i like
my cars low, not ridiculously low but possibly more than your average user.
Is this attainable on the stagea's? Because from what i read it doesnt appear
as simple as some other cars might be. Oh my stagea is a S2 99 RS Four S,
and i know the restriction to do with the exhaust but any other major issues
apart from that? Also i had tein superstreet coilovers in my last car (13b s13)
and i didnt find them uncomfortable at all, and they were adjusted fairly stiff.
So back on point anyone know of or using coilovers in their stagea? Was
wondering on those G4's from just jap as i heard they are quite adjustable....
Tein make 3 different setups that I know of for the stagea. I was looking to go down this path but so many people have recomended SK's kit that I decided to go with that. Would rather go with something thats been tried and tested here on Australian roads. You've got to remember that the Stagea is no 1400Kgish S13 either. And although you could technically buy a mixed set of coilovers (GTR front and GTST rear) from any brand like has been said in this thread many times the front will be ok more than likley but the valving and spring rates for the rear will not.
If the only thing your looking to do is get your car as low as you can go if you order the kit off SK you can get even more circlip grooves machined in but you'll sacrafice handling. One other forum member had this done if you read back in the first couple of pages of the Suspension Group Buy Thread.
And as for the G4 coilovers from Justjap I don't think they do anything stagea specific. Look at nengun.com and you'll find a few sets for the stagea.
I think its going to be a harsh ride 10k font 8k rear, but I'm no suspesion expert either. Others here would be better qualified but I also know what they're going to say :blink: You should read what others have said about running jap spec coil overs on stageas here in Aus. Some ended up swapping them out for something else. If your set on coilovers I'd look at some of the Tein Wagon series, they have lower rates which would be better for street use I think.
Also while I'm at it. When all my parts get here I'm doing a complete brake overhaul on my series 1. The only thing I haven't sorted out is the brake shoes for the hand brake setup. Does anyone know the part numbers, availability and how easy they are to do. Never done them before?
just finished reading through all 25 pages and man do i have a headache :thumbsup:
Welcome to the Stagea section, Alex! I see you got your name change request done... :(
Anyway, onto your question, about a month before I came and met up with you, I had the Sydneykid kit installed onto my car, and I love it! It's not adjustable for damping, but the ride height can be changed with the circlip grooves as Josh has mentioned. The valve rates have been set up by Sydneykid to suit our roads, and although it is a bit bumpier than the standard set-up, it's by no means harsh compared to what the rates on those Teins would probably be like. If you do want to go with a set of Teins, most people here would probably recommend the Super Streets.
*Also, when you do order your suspension (whichever way you decide to go), then make sure you specify that yours is the factory manual, as the rear suspension sub-frame is different to the auto models.* I believe, from memory, that the RS Four S has an R33 GT-R sub-frame rather than the R33 GTSt one.
Nick
Thanks Nick,
Most helpful as usual. What do you think of Buddy Club vs Tein? Can i use those whiteline swaybars as well? Like i said i'm a total n00b
when it comes to these things, prior to my Silvia i'd only had Gemini's and the like, and they were lowered courtesy of Angle Grinder
Performance hahaha! Also another question relating to wheels/suspension, the wheels im looking to get are 19's, and come in either
19x8 or 19x9.5. Would either of these have issues fitting with the suspension? And as long as the total outer diameter is the same, can
i put on 19x8 at the front and 19x9.5 on the back, or does this cause issues with the AWD regardless? Sorry if these are silly questions
but if you dont ask you dont know!
Alex
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
