hmm..yeah i'm going to try other places as well (with the execption of centreline - last time i spoke to them they just kept pusing for coilovers, nothing else - told him about SK's setup and still wouldn't bunch)
how much did you get yours Ryan?
(wish i had the cash and knew you had the SK Shocks - would have brought them of you...oh well too late)
i think they were 1200sh or so, got the receipt somewhere, but i had them overnighted as mine were blown, then got springs for 300 through the group buy(and got ripped on my shock return)
Edited by Ryan1600
I have found Trutrack suspension very good to deal with in the past they may be able to help you. They stock Bilstein, Eibach and Whiteline stuff and should be able to sort you out with anything you need. They are in the city.
There website is www.trutrack.com.au
hmm..they (Trutrack Suspension) are in North Melbourne near Suspension City...I'll have a squizz and kick over some rocks (right now i'm just looking at prices - don't have the money to get them right now)
Edited by BigDirtyJase
Well I'm still in the hunt for suspension - I've always wondered about the ISC N1 Coilovers. Has anyone got them installed and how are they.
I looked at the standard setup of 12kg on the front and 10kg on the rear is a bit harsh but Ryan at ISC told me then you can change them prior to purchase (either 6, 8, 10 or 12 kg on the springs)
what would be the best spring rate in your opinion
gonna guess at 8/6 - 8/7
i think 8/6 tho, seems like the front needs to be stiffer than the rear, and a 6kg spring is enough for a decent load in the back
~3.5/4 is far too soft!
just make sure he matches the valving too the spring rate!
Edited by Ryan1600
I've read through this whole thread and haven't been able to find much info on rwd spec.
I was wondering if anyone can tell me if I have any other option other than to order either tein or s-tune set from japan.
Had a bloke look at it today he said there was nothin he could find for me. I'd either have to order from japan or maybe NZ.
Is this true? :sweat:
Is this true? :P
is it the same as 260rs but with softer front valving? or diff struts all together?
Is this true? :P
As GorGasm said, the front suspension is completely different between RWD and AWD Stageas...
Hmmm yes as I found out today. Well Gorgasm pm'd me some info, so maybe once I start to get mine sorted I could start a post for rwd spec stags...
  • 3 weeks later...
Hey guys im looking at buying a stagea 260rs this week and was wondering what coilover options i have, i also want to know what kind of wheel width and offset i can go as im looking to buy some Nismo LM GT4 wheels for it
Well apart from the obvious advice, which would be read this thread, and take a look at some other stuff on SAU (you can find a lot with a search for 'stagea wheel dimensions' etc), like this thread here - stagea wheel dimensions, I would hazard a guess and say that they will fit OK - I'm *sure* I've seen them on a few other stags in Japanese photos. But Mike will be able to tell you for sure. He seems to be the resident wheel-fittment guru.
so wat do we have for M35's???
Heaps in Japan...
Bilstein BTS (adjustable and non-adjustable)
Nismo S-tune
Tien Super Wagon (with or without the electronic control)
Aragosta
HKS Hipermax
Ai Star
RSR
etc...
I do not know if they are all compatible with ARX though.
Bilstein can be put on ARX (just ask Jetwreck & Andy65b)
Nismo cannot.
In Aus?
I only know that Pedders can make a "Sports Ryder Extreme XA" adjustable kit for any M35.
Oh yeah, and SK (when he was around) had a kit he would make up as well (big money though).
Edited by iamhe77
Hi everyone,
I've done my head in reading 1000s of suspension posts, looking for a suspension upgrade for the stagea (s1 rs4). I am wanting Bilsteins, I have the part numbers for those, they are not a problem. Front springs are no worries, but the rears....... what a pain.
I don't have standard springs, and the ones I have in there are unsuitable. And I don't want to go coilovers due to the legality issues.
Early on there was a post saying that the part number for the rears was 70191 (whiteline) which was great, until I found out that Whiteline have ditched spings from their line up. A quick phone around and I can't get any.
Where I'm at now is trying to find a set of springs to suit the stag. I don't want to increase the rate too much. Don't want to wait 4months for some teins to come in. And the SK group buys are unreliable at best at the moment.
What I need is either
-the specs of all 4 ofthe original springs (coil id, number, diameter, free height etc) so i can get a set made.
-confirmed part numbers from the sk group buy or what they are for (pm might be best)
-part numbers / info from someone who has had a set made up
Thanks guys/girls, muchly appreciated
Edited by Race__24
Also, another quick question. If you change the shocks to bilsteins with stock springs, what height does it give you at the standard circlip position. Is there a change or are they dimentionally identical?
We're talking - B46-1471 for the front (r32 GTR)- B46-1916 for the rear (r33 gts-t)
Sama as SK group buy from what i can tell
I'm going to get lowered springs made up to suit the standard circlip groove.
Try and sort this spring mess out for good.
Edited by Race__24
Just an update on rwd spec options. Have had lots of help from a few others who have rwd's. But I've found a shop in brizzy "southside supspension" who will order me in some bilstiens to fit the front for $350 a pop. Which seems like the cheapest option for quality supsension, so I think I'm gonna go with that.
:down:
