If Z33/V35 coilovers fit M35's, does it mean that Z33/V35 lowering springs will fit intoi M35 standard shocks?
They'll fit but it'll be no good; theyre not designed for the weight.
i've been reading and researching about v35 coilovers and if they will fit m35. I quoted the above posts just to know more about it, can anyone please calrify, cause if the spring rate is the issue, is that mean I can change springs and retain the dumpers right? - since that my Sister is selling her V35 with BC coilovers
I might just buy this from her and install it to my ARX -
sure the springs will fit, but they will be the wrong spring rate for an M35
unless the Z33/V35 is AWD, the coilovers will NOT fit. the front suspension setup is different to accomodate the AWD drivetrain.
  • 1 month later...
  • 1 month later...
Hmm...I was watching Inside West Coast Customs and in one of their cars they were installing Pedders coilovers....I checked out the website and for shits and giggles I wanted to check if there is one for a Stagea
surprise surprise there is for the S2 I believe
1996-2001 Stagea WGN34 Wagon - 16-0174 Extreme XA Coilover Kit
wonder if anyone has used them??
Probably worth reposting this here:
http://www.skylinesa...gable-with-gtr/
From this thread (the stagea suspension thread) I gather a shock meant for a R33 GTR will fit the RS4.
Is it going to work well as a stock comfort replacement? I figure it would be stiff going on the GTR, but the stagea is heavier.
Any good local places to pick up replacements from?
auto's need r33 gtr front and r33 gtst rear shocks
manuals use 33 gtr all round
you can use the gtr stuff, but the valving is different and also worth noting is that getting stuff out of japan could land you near the cost of a new set of coilovers (which can be rebuilt, eg BCs are $75/shock for new inserts)
Thanks, Ive already fixed the rear shocks up with some new KYB's.
Im open to new coilovers on the front, but maybe in future. Need to get the car back on the road.
When you say the valving is different, what is the on-road effect going to be?
was wondering if any of the m35 drivers have used the cusco suspension.. otherwise il just stick with the proven bc's just thought id try be different
link
http://www.rhdjapan.com/cusco-comfort-zero-1-hyper-rubber-coilover-kit-nissan-stagea-m35-nm35-61387
link
http://www.rhdjapan....-m35-nm35-61387
I'm sure the quality will be fine; all their stuff seems to be. The picture is a stock image; that kit isn't for an NM35.
I did notice the listed rear spring rates are quite light; 5kg/mm. I'm pretty sure the BC rear spring rates are around the 9kg/mm.
Something to think about if you like to load your car up, or tow a trailer.
Cheers, Dale.
Edited by Daleo
  • 1 month later...
Any more info on that? Ball joints arent likely to be squeaky. Things like sway bars can make very loud creaking noises at the rubber mounts. Worn ball joints make dull knocking sounds if the ball is moving slightly around in the socket. Usually noticeable on rough roads where everything in the suspension is moving around slightly but constantly.
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
