Couple of days ago, i was driving to my girlfriends and i went the back way, springvale road was busy as hell
Anyway, turning onto the back road...i see a station wagon turning right a few cars in front of me.... IT WAS MY CAR. Identical, white, no spoiler, std kit etc, couldnt see the wheels (they were spinning)
I wanted to catch up the guy, but i had to turn off before i could... but it was soooo soo odd seeing myself a few cars infront.
The stageas are coming out now. There are about 6-7 differnt ones that i know of (but still, 7/lets say 500,000 cars is not much)
There is one in Newcastle. someone jsut bought it from the sketchys't caryard around but i looked at the car while it was there... seemed in good nick. Tried to catch him for a race in mum's 9-5 aero saab yesterday but there was to many cars between us lol. thought it might be a close race, was intrested to see how it would turn out. Will have to track it down in mum's car again (would use my car but don't want to embarres him... its only stock)
I've been comin here for a while, and have only jus decided to look in this section.
I think by the description of the caryard u would be talkin bout mine :P
I've put the Blitz NURspec 3" cat back exhaust back on, which was on the car when it came over, and a turbosmart boost controller runnin 10psi.
Have more upgrades planned when the funds are available.
Beastien
  • 3 weeks later...
They obviously have not seen any of the ghost rider dvd's :D
GHOSTRIDER 1, 2 OR 3? Now guys, if you havent seen it, thats some awesome viewing! Volvo's have no chance, as proven by an insane maniac on a GSX1000R!
Spotted; 100metres from my garage with my stagea parked in it, a silver Stagea with personalised plates.
Out of the less-than-a-dozen Stageas that live in Adelaide, 2 live within 100m from each other!! Now THATS small town syndrom at its best!
Brendan
Ghost Rider 4 is where it's at :D
Spotted S1 97 RSFour+S in my driveway this morning ;)
GhostRider 4 - relase date unknown.....
Hhhhhm, nasty stuff. I once tried some of his highspeed antics on my Fireblade, almost clipped a tray top at 200+ whilst 'undertaking' and decided that it wasnt for me!
As for my post b4, out of 1million residents in Adelaide, 2 out of less than 10 Stageas in Adelaide live within 100metres of each other. Now THATS wierd.
Brendan
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
