spotted a silver series 1 stag at the lights on beeliar drive near the BP service station at Gateways shopping centre was heading away from the freeway waved but driver didnt see me was in the Territory stags not left Japan yet funnily enough its the same colour as mine
I drove a pearl white one through Glen Waverly in melb 4 weeks ago an loved every minute of it :sick:
An i saw a green one 2 weeks age near chadstone shopping centre an was like HEY >_< but it was green an looked a bit yuk. it was in great condition just i dont like the green.
Im arranging to get one soon, dark blue, stock for now. just subtle mods to keep of the cop radar. But i plan to make it a machine an a half
I drove a pearl white one through Glen Waverly in melb 4 weeks ago an loved every minute of it :yes:
An i saw a green one 2 weeks age near chadstone shopping centre an was like HEY :D but it was green an looked a bit yuk. it was in great condition just i dont like the green.
that one in the pic looks awesome mate, is that yours is it? what front bar is it? :( looks almost black too
nice ride :)
yesterday. saturday 8th july.
Around midday.
Sunshine plaza Shopping centre, Maroochydore.
spotted by my mum, actually.
Light silver Stagea, wouldnt know if it were S1 or S2.
Said it was very nice and tidy looking - immaculate, even. She even went as far as to say it looked like it was owned by a female. Thats the feeling she got, anyway. didnt elaborate.
Whos gonna own up to THAT one?
Spotted STAGEN parked outside the little maccas on the corner of St Kilda rd and Toorak Rd.
EAsily one of the hottest stags in Melb if not the hottest.
amen to that, brother.
would love to see it in the flesh one day.
Around midday.
Spotted a nice sounding silver one at the Buderim/Mooloolaba turn off..
Sported some form of front lip.
Edited by Drift_Limo
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
