spotted red series 1 reg STAG-- tonkin hwy thursday am,series 1 silver QLD reg in subi centro friday pm,RS260 ? series 1 white saturday evening beaufort street highgate.
Spotted the Dayz Blue with the blonde again. Southport Nerang Rd S13 saw dark green like mine down the coast also. Seems to be a few about here but dont seem to be members which is a shame.
Down here in Adelaide I barely ever see a stag on the roads. Today a mate and I went to Sinergy Motorsport to have a look at a few and on the way guess what we saw..... dam right a silver series 1 turning onto Kensington road. Cut everyone off from the right hand turning lane and went straight to catch up for a closer look. Stock as a rock but still very nice. Im sooo keen to get one now :)
Spotted at Erina in Fountain Plaza some weird arse green coloured freaky looking Volvo wagon i think with stagea badging.... number plates STR86T....guy looked really really suss. lol :D
No Whey!!!???!!!???111???
Spotted a S2 in silver with Dayz front bar and a dark green stock one, both as stage cars at todays targa west. Also spotted Appealing both yesterday and today as advance car. Looking good there too d00d.
fone imige sucks but spotted a serries one stag at the snow last month 26th sunday august about 3pm in smiggin's car park. had a nismo sticker on the windscreen and i can't rember the number plate. was on a bus or i whould of got a beteer pic
Was at Raceway Power Cruise Saturday, very nice black, yes black, S1, Twin sunnies, leather, really smick white wheels. Chatted to lady owner,
dont think she is a member.
It's a shame that there are a lot of owners who are not members.
spotted the white s2 with stagea plates in maroubra thismorning he was about to cross anzac pde. ive seen it a couple times now.just never get the chance to pull him over lol. slow lux v stagea i think not lmao
Agreed, especially seeing as we could get a better idea of the number of Stageas really on the roads here in Oz.
Maybe they don't realise how much help we are to each other, and could also be to them if they encounter any problems with such a unique car in Australia.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
