I just spotted the same white s2 twice in the space of about half an hour. Number plate was ORG13Z. I spotted it both times on Seven Hills Road/Old Northern Road from Seven Hills through to Baulkham Hills, once while I was on my way to the car wash, and the second time when I was on the way back home. We were going in the same direction both times, so I'm guessing he's a local.
First time the driver had a (teenage?) male passenger, and then on the return trip the passenger was female.
Nice trade-in! :rofl:
Well I have got the wife is well trained. She has borrow my car and is in Ballina at the moment on holiday's....she just rang to say she has spotted a nice silver s1 or S2 at about 4.30PM
spotted this afternoon hektik180 at waterloo, had a quick chat about the lpg conversion done to his immaculate example of a stagea
and im glad that finally someone from the forum spotted my pride and joy.
spotted white and silver series 1 stags at jindabyne last week the silver one had qld plates and was parked in the thredbo carpark... i flashed the white one as they were driving towards thredbo on snowy mountains highway no flash or wave back tho
series2 white sitting on railway ave west leedie ,on thursday,pm .white series 2 i was having curry & see them drive past +it was raining kardinya street north perth 7,30pm ish ,cheer`s chuckie.
spotted s1 silver stag on trappers drive turning right onto whitties ave with female driver on wednesday arvo around 2.30ish
spotted s2 white stag driving through wanneroo markets this morning
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
