Spotted a white RS4 on Albert St in Brisbane city yesterday at about 6:10. I was on my pushie, waiting at an intersection. It pulled up nice and quietly next to me and I spotted the bonnet line out the corner of my eye. I said g'day to the guy in the passenger seat. Anyone on here?
Edited by BoostedBarge
a bit of fun for everyone.....got on goggle maps today and spotted the back corner of my M35 next to the trailer on my parents driveway.
I know it's trivial and silly but I bet you will try it :b
hehehe my car in the car park at work
pfft to google....I spotted jetwreck in north ryde early this morning.
r u shore on this morning....every other morning yes....last night I had 2 P4's and 6 beers......hope I was not sleep driving again....lol
Duncan two things.
*r u coming out to muscle car?
*and you now the other? think about it this way...more finance for your r32 project.
P.S. P = panadine, 4 = sleep, 6 beers = more sleep.....I need it after 5 double shifts in a row!
spotted a white stagea on the side of the mitchel freeway tonight...around 8ish?? Hope nothing was wrong. I was in the middle lane and couldn't stop, not that me stopping would of been any help as I know didly squat lol
if it was under the erindale road bridge south bound that was me lol.... was waiting for my mate.. we were heading out for a cruise and i didnt know where we were heading... real smart hey..
Spotted 2 Stag's this week.
1st one on Abbott Rd in Seven Hills earlier this week. I think he came off the M2. White S2 with his fog lights on.. I actually seen him, same car, same spot same time when I was waiting at the bus stop before mine was delivered..
Spotted another Stag this morning around 8ish. Coming down Church St in Parramatta near the Victoria Rd intersection. White S2. Male driver, female passenger. I gave him a wave but I don't think he seen me! ;)
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
