gold M35, black rims, very nice! coming from seven hills, i was getting off the M2 at the lights.
hey buddy
off the m2 off ramp?
i was coming back from hdi after my fmic install
thanks for the spot!!
yay!! first spot in 7 months of onwership of the car
Spotted white C34 RS at Rosehill shops last night bout 7.30 (think it was BJK..) parked next to my bike.
hmmm i live in parklea... once again where are all these stags in western sydney coming from...
hey buddy
Yep i was coming off m2 onto old windsor at the lights and you were on abbot rd turning onto old windsor. caught my eye quick smart lol.. as i said very nice!! love the wheels
eh pitty i didnt spot you
you should have flashed your lights at me or sumthing :)
Spotted a few M35's out and about the past few weeks, mainly on the F3.
ARX rego A*X25T, I think it was a white one, looked fairly stock from the outside.
Friday evening just gone a Gold coloured ARX rego UF ### didn't get the numbers, we tagged each other all the way from Kariong servo to Berorwa exit, where he departed. Gave a honky honk and he waved out his window.
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
