Dude, you had two s1's right in your neck of the woods last night - we had a dyno day at Unigroup and went to Fully Tabouli at Pemulwuy shops last night afterwards...
think its time i came out of the shadows and said hello to some members
i parked my car at pemulway last night and some kids are going
" brooooo that station wagon is turbo " "what the f**k is it"
im glad they didnt realise i got out of the car
Today I spotted three dark green Stags.
First was in Ashmore Rd
Second parked in construction site near Aussie Fair
Third was in my garage.lol
We are not the only ones Nick!
spotted an m35 broke road in pokolbin (hunter valley vineyards) with the plates ST***A looked sweet, i have seen this before i think at one fo the meets/shows
and got a wave from white s1 in lochinvar on the way home, 2 in the same day lol
That would have been Iain (ziel20l), must be a dirty weekend away with the missus!!
Busted! :nyaanyaa:
Probably even worse if he didn't take his missus, could be some gossip on this one.
Nice spotting :nyaanyaa:
spotted a silver m35 in the riverstone/schofields memorial club car park last night.....possibly the one i always see on annangrove road?
also today spotted a gold arx parked on a road near canterbury road today, around 6 maybe...
now all i need is a bronze and i have the whole set yeh? :nyaanyaa::nyaanyaa:
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
