I came across this website yesterday, surprised to see that Stagea's are so well supported. I've been using a 1997 RS Four as a site car in Micronesia for the last couple if years and given it quite a lot of stick, need to keep it going for another year to see this project through. Suppose you could add this to the spotted list
There were 12 , including the uber cool bastard that just drove past and did not stop - like your style - sunday 24th oct 2010 , since being ousted from the GTROC UK ! the stagers owners club have been positive in there coming together and surviving quite nicely . more shots here http://www.facebook.com/home.php?#!/al...p;id=1311100133
Second time I have seen him.. I have to ask though it's looks way lower then mine and I struggle so much with bottoming out on speeds bumps, carparks etc. Does yours scrape alot??
Its not too bad. A bit of angle gets me over most things untouched. I originally had it about 2cm lower than it currently is and it was a nightmare, but seems perfect now.
I'm disappointed that I DIDN'T see a Stagea up for the challenge against the Merc AMG SLS, the Porsche 997 911 turbo and Audi R8 v10 - I think it would have kicked some butt!!!!! :P:D
I tried a few times.. but was disappointed.. :down:
^^ might come next week!! When and where??
Spotted spoolin this morning on my way to work in frenchs forest
http://www.skylinesaustralia.com/forums/ca...&hl=Coastie
Every Thursday night (I'm there almost every week, but sometimes I head up early so I don't stop at Berowra because there''d be no-one there).
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
