spotted 2 yesty aswell, one goldish looking m35 on bextley rd, near canterbury rd, parked on the street with chromies on it and another white rs4 c34 with greeen p plates on it on king georges rd in beverly hills.
Grey series 2 with dayz kit cruisin down south road @ old noarlunga at about 6:20pm today, turned off to go to seaford.
was being stealthy in the wife's car :P
might have been us going to the seaford hotel
Spotted two stageas yesterday
one red RS four cruising inbound on the monash near wellington road at about 2:00pm
1 white one turning onto monash from princes highway near berwick. :P
Wooo got spotted first time shes been driven in ages
just spotted a white series 1with dayz kit on an advert for today tonight for speed cameras should be on tonight tuesday....also spotted a white series 2 on toorak road and the s.e freeway in vic at 150 pm today with dayz body kit young bloke driving dont think they saw me i was on auburn road
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
