Spotted a Black M35 at Crown on Saturday night. Was doing the same thing we were (driving around looking for a car spot). Flashed the lights but didn't get a response.
Saw posibly the same one Yesterday arvo on Errol St in North Melbourne.
may it was me :down: i remember being at crown looking for parking around 7-8ish on saturday. n i work in the city..
dont remember seeing a white stag though? is there another black one in melb?
and I spotted a White Stagea the other day.. I was at Scott's house :ph34r:
Edited by AaronNM35
may it was me :) i remember being at crown looking for parking around 7-8ish on saturday. n i work in the city..
dont remember seeing a white stag though? is there another black one in melb??
Probably was. I realised afterwards I don't think I pulled back on the stalk properly so the highbeams wouldn't have flashed. I would have stayed behind you but the missus thought she saw a free space and well... you know what Crown was like Saturday night (turs out it wasn't a freebie anyway :ph34r: ).
Ill jump on hte horn next time :down:
yeh man definately! i thought it might be weird to just drastically beep and flash at another stagea, but since theres a thread....
lets just say I see a f**k load of stageas in my area.. my mate 55 year old mum drives a silver series two with a FMIC and an exhaust.. from what I can remember.. haha
Spotted
Silver M35 Stagea in Wodonga. Custom Victoria rego with white lettering on Blue background. Looked nice.
I hope to see more stag's going around here. To my Knowledge im the only Wgnc34 here. Besides a few Ive seen driving through!
Spotted
You should be seeing a dark blue M35 around those parts as of Feb next year.
My mate is moving up there from down here and taking the $500 M35 with him :banana:
Edited by iamhe77
spotted a white m35 BTG--- at about 4.30 today in new lambton exchanged waves
You beat me too it. I'm in town till Thursday if your cruising in the area again and wanna have a chat.
I live just around the corner on Russel Rd some days.
Spotted blue M35 New Lambton stalking my back alley way.
Edited by Tonkachow
Spotted a white M35 turning off Buffalo Road in Ryde this afternoon, i tried to catch up but some stupid P plater cut me off. I think you live in the street I used to live in
not all us P platers are shit. Seriously, I drive a Stagea. :P
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
