pulled up beside a white RS260 C34 (had autech kit? and RB 26 ?? plates) with biggish wheels, lowered with a cannon tonight about 6:30 at the lights on the highway going towards jerrabomberra. gave a wave and he looked at the car and im thinking "faaarrrrk my stagea must have a lift kit its sooooo high and my brake calipers look so tacky (painted black with nissan stickers on them when i got it). both gave it abit on take off and he zoomed off in to jerra.
Edited by RS4-S
Today,11:30 on monash freeway ,silver S2 heading towawrds the city ,I was going the other way (after getting a pair of R33 front callipers for the stag :banana:)
I was like looking at my self...
Spotted Rosella's Stagea in my garage with the front all pulled apart.
Now it has a shiny new intercooler!
Wish mine did...
Thanks to the assistance of Dale I have a great addition to my car. :worship:
Now pity my car's not red then it would go even faster. :rofl:
Now can't wait for the sway bars.
All good, kicking back with a Squires at the moment mate :thumbsup: .
Hey jetwreck that was me finally got spotted, your arx is nice man, very tough looking
Ahh....so your the Stig!
LOL.....good to see yah...you will have to come to the NSW meet when we get our shit together!
Yeah I am but dont tell anyone :ph34r: guy actually asked me who the stig was the other day haha, and yeah will definately try and make it to a cruise some time
Mines red......... maybe we should have a race. :D
Oh yeah, saw white 260RS on warringah rd turning right onto pitwater rd this morning about 8am. Followed him as he turned onto mitchell rd then I had to turn off. I was on a black VTR1000, not sure if their on here but had a pink shirt stuck on the back window.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
