I actually spotted this car nearly a week ago. White C34 in King William street Adelaide, around 1pm on Friday.
i was actually checking my phone while waiting to cross the street when i heard a car give it a boot full, along with a BOV sound as it changed gears. i looked up in time to see it fly past me. a guy standing next to me said "not too bad for a Volvo"..... still not sure if he knew what it was and was joking, or if he meant it? i couldnt tell from his tone of voice....
Black Stagea on prinny hwy this morning, gave it a nice boot next to me :)
Wasn't me....but I could take a guess at who it was!
could only be one clown!!! Aaron! :P
lol yeh probably. i been ummmm late the past few days!
Saw a white series II C34 RS four with a full Dayz kit just now parked just around the corner from my house down a street called Arnold st near the Hackham east primary school near the old coles shopping center off Collins parade
maybe 4pm? and possibly S1 front? Otherwise i didn't see the S2 :(
Spotted a yellow S2 RS4-S (pretty sure) with a fronnie, on showground Rd, looked hot, i was in the Hilux dammit, never in my stagea when i see other stageas..
Hi guyes my name is adam i live at top ryde i have a c34 rs4 white rego bcq60e and my mechanic boss tuning working out of carline gladesville has a silver c34 rs4 rego fossil with r34 gtr rims who else lives in ryde with stageas ??
I live in West Ryde and have a Silver ARX M35.
I will watch out for you.
Cheers
Andy
I know this car!!
he used to own BD4's aye???
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
