Bugger! I take it you just unplugged and drove in "limp mode"?
Lucky you have a spare...:whistling:
yes i did, and yes i do
fixed it when i got home :)
how do you manage to drive in limp.
i had the afm unplugged the other day.. it would start then gurgle and shut off..
Might have something to do with running the eManage and E85.
I can unplug my AFM and drive no probs... Won't be a great drive by any stretch and there will be stuff all power or revs.
could be..
i do remember driving it once in limp..
when i was new to the car thought it might need a good boot. (lets just say that didnt go down too well lol)
spotted a black M35 pulling into autobarn belconnen. had black multi spoke wheels and a white and orange nizmo style stripe down the side. best m35 ive seen in the flesh. i was pulling in to the holden dealier in the blue VE R8
That sounds like Craig
Spotted a black s1 Autech on the corner of Prospect and Regency about 2:30 with NO plates on, not even traders. Pointed at him then gave him the thumbs up, wasn't until the missus reminded me that we were in the focus that his "WTF" look made sense :whistling:
Lol....to funny....was down there helping someone out with a turbo change in there m35. Got stopped a little earlier buy someone on the road....told em it was a Volvo! :P
haha sweet, i was kinda wondering if it was yours. looked tough as coming up the road.
that stupid ramp that you drive down to get outta the autobarn carpark, my stagea is normally parked up to the left but i had my ol' vw today.
Spotted on the weekend a silver stagea M35 with GTR wheels around Burwood. (VIC)
Spotted last night a silver C34 giving it the berries driving down blackburn road (I was on burwood Hwy)
This morning, spotted a white M35 driving down wellington road!
I hope one of you spotted me.....I haven't been spotted yet! :action-smiley-069:
That was me. i was driving back from the mech had the permit in the front window as it still needs to go to regency for plates, it would have been done by now but i'm still waiting on parts
Spotted white ser1 turning right from yanko rd to lanecove rd in I think its chatswood west and spotted blue I think it was ser1 at bp filling up in westryde both within an hour of eachother if I had seen a third one within that hour I would have brought a lottery ticket $$$$
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
