silver C34, think it was a 260RS, top ryde today around 2:30pm, thanks for waving :action-smiley-069:
was that you in the black S1?? if so it was me at top ryde. irs a s2 Rs4s with takeros body kit :D nice stagea btw, love them in black and it was clean as a whistle.
indeed it was me in black s1, cheers,
the kit on yours made me think it look like a 260,
To the red S1 on Hancock rd near the Blue Gums, thanks for the tututtuttuttu and wave, nice lowness.
For the folks with the white RS4S with the reallly white wheels near Bridge rd, it was good to see you having a good time on Billabong rd, mine was parked at my bro's place.
Hi to the small family of white Stags on Montague rd near the Clovercrest, didnt you guys used to own the one with chrome wheels and the big black flames on the side?
To the owner of the stock looking black S2 near the Redwood park shops, congratulations, an early christmas present perhaps?
Hi to Russel with the silver S2 with the gold BBS, hows that brand new secondhand turbo treating you?
A blue m35 cruising down princess highway from muno para towards city. Join u just before Elizabeth shopping centre around 5.50 nd then around 5-10min later a yellow dayz edition crossing princess highway from mcintyre rd.
import_zone.......princess highway = main north rd right? Do you still have your S2 or did you end up selling it? If you spot silver S2 with white Grays style 19s, standard ride height, twin pipe box on the back, thats the other Unicorn in our stable.
Edited by Springsteen
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
