Vic spotted, stock m35 grey arx on Wellington rd, rowville about 3pm.
...... Badged as M35? Wierd......
Hi Troy, that was me. Why is it weird? I have been looking to buy the Stagea and ARX badges to put back on the car, but cant find them. The M35 badge is actually from an Infiniti M35. Replaced it when the tailgate was re-painted a few months ago. Car actually came with M35 badge when I got it. I think it keeps people guessing even longer.
My V36 Coupe has all Infiniti Badges including the drivers airbag.
Nice to see your ride mate, I was next to you in the grey pajero trying to see an infinity badge on the grill ; ) flashed my lights also.... Then remembered I wasn't in the stag.... : (
Wierd cause I hadn't seen that badge before.
Blue M35, parked Wolsley Place, Thomastown today. Had a busted front fender.
digging up an old post.. but i think that was me. out seeing a customer..
But the only time i get seen is when i had the ding. All fixed up now.
on another note.
saw a black stock (looked stock) M35, you gave my car a good look over.
I gave you a nod and a lil wave but not sure if you saw it.
Driving city bound on the eastern fwy, 740ish tuesday morning.
i get a little excited when i actually see Stags getting around.
I feel like the only one getting around at times.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
