Vic spotted, stock m35 grey arx on Wellington rd, rowville about 3pm.
...... Badged as M35? Wierd......
Hi Troy, that was me. Why is it weird? I have been looking to buy the Stagea and ARX badges to put back on the car, but cant find them. The M35 badge is actually from an Infiniti M35. Replaced it when the tailgate was re-painted a few months ago. Car actually came with M35 badge when I got it. I think it keeps people guessing even longer.
My V36 Coupe has all Infiniti Badges including the drivers airbag.
Nice to see your ride mate, I was next to you in the grey pajero trying to see an infinity badge on the grill ; ) flashed my lights also.... Then remembered I wasn't in the stag.... : (
Wierd cause I hadn't seen that badge before.
Blue M35, parked Wolsley Place, Thomastown today. Had a busted front fender.
digging up an old post.. but i think that was me. out seeing a customer..
But the only time i get seen is when i had the ding. All fixed up now.
on another note.
saw a black stock (looked stock) M35, you gave my car a good look over.
I gave you a nod and a lil wave but not sure if you saw it.
Driving city bound on the eastern fwy, 740ish tuesday morning.
i get a little excited when i actually see Stags getting around.
I feel like the only one getting around at times.
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
