Vic spotted, stock m35 grey arx on Wellington rd, rowville about 3pm.
...... Badged as M35? Wierd......
Hi Troy, that was me. Why is it weird? I have been looking to buy the Stagea and ARX badges to put back on the car, but cant find them. The M35 badge is actually from an Infiniti M35. Replaced it when the tailgate was re-painted a few months ago. Car actually came with M35 badge when I got it. I think it keeps people guessing even longer.
My V36 Coupe has all Infiniti Badges including the drivers airbag.
Nice to see your ride mate, I was next to you in the grey pajero trying to see an infinity badge on the grill ; ) flashed my lights also.... Then remembered I wasn't in the stag.... : (
Wierd cause I hadn't seen that badge before.
Blue M35, parked Wolsley Place, Thomastown today. Had a busted front fender.
digging up an old post.. but i think that was me. out seeing a customer..
But the only time i get seen is when i had the ding. All fixed up now.
on another note.
saw a black stock (looked stock) M35, you gave my car a good look over.
I gave you a nod and a lil wave but not sure if you saw it.
Driving city bound on the eastern fwy, 740ish tuesday morning.
i get a little excited when i actually see Stags getting around.
I feel like the only one getting around at times.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
