White s2 with dayz kit nd spoiler on smart rd nf then followed onto McIntyre at around 9.30 this morning.
Yeah, was having a bit of time tuning some new stickers, hitting various cuts. Got some more on the way. Liked the na grille.
Was paddling on the river last night and spotted a silver series 1 in the car park by the Onkaparinga Canoe Club. No-one was in it for me to wave to and considering I wasn't in mine I would have just looked like a weirdo anyway lol
Whilst my white s2 was parked next to a mate black s2 in the front of tyres and more, my bonnet up! A silver stag drive past!
Should have joined the car park!! Hahaha
And also saw a silver m35, with woody panels down the sides and across the boot! Parked next to prospect oval!
