on Cowarra st taren point i saw a Silver PNM35 at a fiberglass place and then while i was watching it a White C34 drove past then of course there was my Black m35, i personally have never seen more stags in one place at one time.
You should cruise down to stagea hks Nismo fully sic bro garage sometime! ;p
Spotted a Black Series 2 on Main South road, just near Flinders UNI in Adelaide at about 1:20PM today.
Also spotted a White Series 2 on Flagstaff road at about 3am on Saturday morning. Turned off before I caught up.
Very nice s2, blue, pulling on to hawker street this morning. I was in my pulsar so didn't wave today. Seen you around a few times.i live over the road with a white s2, in the shed at the moment few little things to do.
Spotted a Silver C34 pulling away from a park in Emu Plains when I was pulling up.
My young bloke saw a tractor in the park; so that's where we were going (with a minor detour to the Nissan dealer first).
spotted a S1 260RS on Victoria rd this morning. followed it all the way to harris st where I overtook in traffic. looks good in the grey!
If it was Lowered on bronze works wheels then it was me, thanks for the spot.......looks the best in grey ;)
I'm guessing you were in a skoda and not a stag anymore, would have noticed if a stagea over took me.
Spotted a silver 350RX at the Sydney Datsun Show today @ Prospect Hotel. It was parked around the back as if it was being hidden away... :(
277197_10151158013215369_1923639940_o by GoldZilla, on Flickr
Spotted a White C34 turning onto Grose Vale Rd in North Richmond this arvo.
Was in the far left lane on my Black Gixxer 1000, and didn't notice until you'd pulled away.
Plates look good, pretty nice exhaust note too. ;)
yup sounds like it was you! you work around the city? I turned off harris st as I passed you. yeah was in a dark grey Octavia.
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
