Spotted Gavin again this time down Powers Rd and up past Winsto shops, beeps and waves :) Also spotted a silver arx on Abbott Rd 8am, and saw a black arx, looked dumped, turning right from Caroline Chisolm Dr onto Old Windsor about 7:30pm Tuesday night, chick driving.
Pearl white S2 RS4S Dayz on Diamond Creek Road this arvo, bout 5:45pm.
I was the dude on the R1 who gave you a toot and wave as I passed you.
Very, VERY neat car. Wish mine was that clean >_< Damn not having a garage!
HAHA, was late leaving work & thought I'd stalk you the long way to Norwest Private!
Also spotted a silver S2 C34 turning onto Perfection Ave Stanhope Gardens at 8pm tonight.
Haha! That's awesome, I saw you give it a boot after going passed, I pickup my daughter from mum & dads in baulko every Friday. Love your ride man, makes me want a c34, there's a few really neat ones around the area, only one yellow one I've seen but!
Crap, I live in the area too and rarely see anyone except StageIan in his red s2.
Yeh I'm always looking out for you either down the end of Targo or when I'm over the other side of toonie station but yet to get a spot!
Hey Nick. I've occasionally seen a green S1 just like yours around Quakers/ The Ponds. I was nearly tricked the first time i saw it! I've mentioned it here before without a response, so I don't think they are on here..........
I live on the other side of Toonie station, but have relatives near the Girraween end of Targo Road, so I'm down there fairly often. I also use Targo or Toongabbie Road to get to Unigoup.
Oh really Gav? I've never seen another dark green s1 around here...
If by ripping road you mean Epping Road, that was me! If not, then this is really embarrassing :whistling:
Yeh....epping rd....spell check got me again....black wheels aye? I honked going in the opposite direction. Second time I've seen your car now!
I do remember hearing a beep actually, near The Ranch Hotel? I'm pretty sure we live in roughly the same area, though I am yet to see your stealth M35 despite keeping an eye out for it!
Black rims = win on the AR-X, it's a good option with the plastic arches IMO. My car is getting new rubber on the rears, Falken of course... :whistling:
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
