saw RBPOWA (SP) on glynburn road.
That would be me. I take it u were in the s2 rs?
Also spotted a s2 bayside blue at the bp on lower north east rd as I pulled in to get fuel u were leaving
white C34 with gold/bronze rims weaving in and out of traffic, from the M4 all the way up to ryde this afternoon. in my black 34, no love shown =(
:action-smiley-069: hi Chris, sorry too busy hooning to wave :) Nice 34 BTW
Spotted a Black S2 Stagea a few times now around Burwood East over last 2-3months on Highbury Rd and Blackburn Rd
Same with a White S2, also keep seeing a White M35 in same area. Sometimes up on Springvale Rd.
Exchanged headlights, waves, toot the horn a few times.
Yellow S2 Stagea with R34 kit also in same area also.
Got a thumbs up and a wave from the bloke with the other silver m35 down the end of Targo Rd on the weekend.
Dave, it wasn't you I saw the other night on Gilba Road (crossing Targo) and then again about 20mins later in Toongabbie near the servo on Cornelia?
Hey mate, yeh I saw your post, and the times were near when I was getting around those areas, but I turn left from Targo onto Gilba, and you mentioned Junia and Cornelia? I was parked in the servo on Cornelia that's opposite toongabbie shops, I just re-read your post I thought u said Lucretia and Cornelia, not Junia, but yeh for sure that would have been me then :)
Edited by DaveM35
That was me in the Black C34.....probably wont be seeing you on Highbury Rd anymore as Im not working at the same place anymore so taking a different route to work now :P
Spotted a white M35, looked like aero kit on King Georges Rd at 11am right near AutoStyle, was dumped on black rims with copper brembos, really nice looking ride.
Then around 1:30 saw a yellow c34 on Sunnyholt rd Blacktown, near Vardys Rd.
Saw a black M35, most likely an AXIS, on the M2 Motorway heading south-west between the Pennant Hills Road and Windsor Road exits, roughly 5.45pm last night. I was heading in the other direction and about to get off the M2 at Pennant Hills Road.
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
