Was he racing? would be a hard task making our cars fast down an 1/8 mile
You kidding? 1/8 mile is the M35 event. 4WD out of the hole & it's all over before the other guys get a chance to catch up, lol.
No he wasn't racing - we were spectators today. Maybe another time..
maybe if our cars were 500kg lighter. and able to launch propely
spotted very nice gold m35 in burwood today, looked but couldnt tell if u saw the silver stag on how tinted your windows were lol
That was me! Yea, I was waving and wondered why you didn't wave back. Nice C34!!!
Saturday night there was a dark coloured C34 parked opposite Werrington Down shops / Caltex servo.
Sunday morning spotted a black M35 on Cumberland Hwy / James Ruse Dr near the underpass of Windsor Rd. (North Parramatta) at about 10:30ish
and today spotted Taren in his C34/R34 black wagon on Castlereigh Rd around 1:10........ I was on the side of the road in the van on the phone :P
Black m35 was me. I live in northmead and was on my way home from the fully sick nismo workshop
Also spotted a silver C34 at Glenwood shops tonight around 530pm
Spotted 2 today...both in port Melbourne .... White S2.. stopped him and and a chat.. Sorry I didn't get your name... then while waiting for my bus around 5:45 an M35 went around the corner from salmon st on to Williamson road.
Edited by infiltrator
Yeah, I did a 6.2 sec for the 1/8 mile ROFL
red c34 stagea with black aftermarket front bar in roger st brookvale
you drive past my work most mornings and i spotted you around 12 on pittwater rd driving past again :yes:
Edited by R33huntme
Yep thats me...
I take it yours is the grey one parked in roger st I see in the mornings. Looks sweet.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
