Spotted a dark green / black C34 on Wakehurst Parkway northbound yesterday arvo around 3pm. Waved, got the wave back.
Also spotted a champagne 260RS C34 this morning in Neutral Bay heading toward the city near the ferry wharf
Black 250RS M35 in Neutral Bay parked on the side of the road near the Ferry Wharf
And last but not least, a black M35 ARX in French Forest Saturday around 12pm
Went to Rayboostin on Sunday.Holy s#*^t Batman, there was four and a half C34's. One Darrin, a nice yellow S2, a dark green S1 and my very unwashed S1. There was a halfa in the garage. Stagea Heaven.
Hey all, i'm new to Stageas but have a question that is probably easly answered by those that know, i went and viewed a 97 Stag Autech RB26 today but as its the first one i've looked at i just wanted to check with you and see that is normal the VIN plate read RB25DET im hoping this is a chassis thing rather than a engine thing, also why would the steering wheel shake when i revved the engine, didn't have time to drive it but other than those two things and some body issues it was gorgeous although the engine bay was suspiciously immaculate!!
thanks bud, seriously what i wanted to hear, any tips on what i should look out before going any further, i'd get a mechanic to look her over before purchase but just wondered if theres things i should pick up before even getting a mech to look?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
