HAHAHHA DALE! Totally agree, this really gets on my nerves when I see the plates on the wrong end of the car
Gah! They even come with a slip of paper in the bag, telling you which one to fit on which end...
My OCD is making me twitch!
  • Like 1
To me it just looks so obviously stupid that I want to drag the driver from their cars and beat them with the number plate
yeah wasn't really paying much attention when putting then on in the poring rain! thought they looked a bit odd.
Ill sort that out before Brick (the Internet hero) gets MAD!! Lol
I feel so special, have never been called a hero before :)
Spotted gold ARX near north rocks rd around quarter two 3 this arvo, I saw the wave! Was in the white Axis S. I always get surprised seeing another M35.
That was me! I spotted you a couple of hills away on Jenkins Rd, then managed to catch up whilst you were stopped at the lights at North Rocks Rd. Nice looking ride mate - was there a Learner driver driving at the time??
Spotted a black stag going through husrtville today with a gtr badge on the back and matt black rims
That's most likely me with my old gtr badge (the only thing I have left) I had a lot of weird looks at like what is it?? with gtr badge from people.
Thanks for spotting.
Dave
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
