Cheers TJ.
Spotted a Silver (Grey?) S1 at Fountain Gate shopping Centre amid the Christmas Chaos at 8pm last night.
Are they 260RS rims?
If not, they are quite similar (from my viewpoint at "reasonable" speed :banana: )
Spotted a M35 250RS momo edition at Forrestville heading towards Brookvale at 9.10 this morning. Looked nice.
Waved and got a wave back.
So strange pulling up behind one of these cars. still not used to seeing them on the road.
Cheers
Andy
Edited by andy65b
plus they look ugly from behind, even i dont wanna look at mine!
Solution.
1) Tough exhaust outlet
2) WIDE tyres
3) Lower car
if still unsatisfactory, spend stupid money and get the Takero's covers for the lights or the reflectors.
Here are the reflector covers.... (and NO, I do not like the body kit)
Just can't find the pic of the light cover.
Edited by iamhe77
ohh i want a wing for my car!!!
not quite as big as that, maybe an AXIS one or something. but those light covers look ok! maybe its easier to just spray a section of the lights now??
i got the slightly wider tyres now, lowering is on the cards......
What about the Nismo wing?
Bit more subtle?
Hmmm, I dunno, the Nismo wing, in my opinion, looks like an afterthought. It doesn't "flow" with the shape of the rest of the car.
yeah subtle but i dont like it, i agree with nick
Bloody fussy bastards.
Fine. I will look through my stuff tomorrow for something you like.
Please tell me don't want a RICE GT wing bolted on the back!
hey, spotted RBPOWA saturday night on kingsway about midnight,the first one ive seen (other than my own lol) since i got my stagea about 2 months ago
hey was it parked or driving ?
didnt see you tho unless you were one of the many drunks i drove past haha
Also today out side 'Rays Outdoors' in dandy plates were non other then ...... STAGEA
was gonna park in front of it but would of left you no room. looks very nice man
damn right i do!! on the top of the tailgate, probably about 3 feet high, and wider than a standard lane :down:
I'll take what Ian wants, but 3 of them stacked! :)
Hahaha, nah, I kinda like the ones that just subtly extend out over the rear window, like the ones you see on the C34's (and which I wish I had on mine :) )...
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
